Airbrush holder
    April 2006
Airbrush holder
Posted by steiny on Saturday, April 15, 2006 6:37 AM
Any home-made ones out there I can use as an inspiration to build my own?
Posted by Anonymous on Saturday, April 15, 2006 3:02 PM
You really can't go wrong with the Badger 125 that has been redesigned. Really beats the old metal ones. I know you want to build your own, but the Badger ones can be had for $9.00 ( or less in some cases ) and will hold any brush that you can think of.
E
Posted by Anonymous on Saturday, April 15, 2006 7:08 PM
i made this 4 brush station at Lowe's for about 15.00
Posted by Anonymous on Monday, April 17, 2006 11:21 AM
I made mine out of a coathanger, and it has the added bonus of actually securing the airbrush due to the way that the front end is a circle that the nose of the brush inserts into before you cradle the back end.  Note that the cup is level, I holster the brush while filling, and the secure hold makes this a one-handed job, which can help when you are holding a part.
I simply started bending the wire coathanger with pliers with the front end, then proceeded into a snug form, testing every bend as I went.  I then, as you can see, duct taped it to the stand that holds my respirator.  (This stand is actually a Dremel hanging stand that doesn't fit my model, but I got it for a buck.)  This holds the brush so well that it withstands getting bumped and backed into.
    December 2003
Posted by hkshooter on Tuesday, April 18, 2006 8:04 PM
Nice hanger! Pun intended!
I made one from a coat hanger also. Works great and was free.
    March 2006
Posted by NikToo on Wednesday, April 19, 2006 2:00 AM
I bought a tool hook in a hardware store and then screwed it into the side of my spraying booth. Keeps it out of the way as well.
On the bench: Tamiya 1/48 Tiger I: Tamiya 1/48 Jagdpanther: Skybow 1/48 Tiger I Late:
