Iron Man wrote: |
I was thinking of getting a new airbrush because i dont like my aztec and i was sort of leaning towards the Badger Model 200NH.
I do own and use a Badger 200NH which amusingly was a replacement for my Aztec A430. It's a really fine airbrush, and I found it to be a lot easier to use than the Aztek (not to mention it didn't break the way the Aztek did). Being a single action version of Badgers Anthem 155, it gives very good control. My first project with it was a freehand camo on a 1/72 Tiger tank that came out quite nice. As others have related, you won't have to spend anywhere near your budget on it. DixieArt is a good place to shop and if you have any New Orleans/Katrina cleanup worries, I just ordered some stuff from them that arrived at my house five days after placeing the order.
For single action ease, the Paasche H is another fine airbrush. I also have one of those, using it for clear overcoats and acrylic painting. It's a bit less expensive than the Badger 200 and is a tad easier to use. In spite of it being external mix vs. the Badger's more-or-less internal mix, I don't notice a lot of difference in their spraying capabilities. If I could go back in time with the benefit of my 20-20 hindsight, I think I would have just started with the Paasche H Set and then if I ever found my skills and needs exceeding the Paasche H capabilities, I would upgrade to a Badger 100.
For some additional opinions and experiences on single action vs. double action, see this thread...
http://www.finescale.com/FSM/CS/forums/611178/ShowPost.aspx
