Badger 180-11 Compressor Question(s)
Posted by Anonymous on Wednesday, April 19, 2006 11:25 AM
Hi.  A friend just gave me a hand-me-down Badger 180-11 compressor.  Does anyone have any experience with this compressor?  Is it worth using, namely for military (armor and aircraft) models?  Is there a particular kind of regulator I should be using?  Any advice is greatly appreciated.  Thanks!
Dan
Posted by ABARNE on Wednesday, April 19, 2006 1:48 PM
Absolutely it's worth using.  I have the same compressor, but without the auto-shutoff feature and it works great.  Although it is a tankless, diaphram type of compressor, I have never experiences any pulsation out my airbrush.
The biggest drawback is that they are a bit pricey, but that's irrelevant in your case.  Other than a pressur gauge, nothing real special is needed for your regulator.  Because the 180 topps out in the 30 to 40 PSI range, you don't need a real high pressur regulator.   You do need a moisture trap.  My regulator has a moisture trap built into it, but during some recent painting, I had a some moisture problems, so I picked up a Bagder hose with an in-line moisture trap.  A lot of users here have indicated that an in-line trap nearer to your airbrush is preferable to one attached to the regulator.
If you don't have a hose, a Badger 10' foot braided hose with the in-line moisture trap is ideal.
Andy
Posted by m1garand on Wednesday, April 19, 2006 4:29 PM
I just purchased this same model at a local art supply store.  Glad to hear that it is a decent compressor.
Posted by Anonymous on Tuesday, April 25, 2006 11:57 AM
I have this compressor and just bought a regulator and moisture trap for it.  Which way should i hook them up:  compresor, reg, filter or fliter then reg.  Thanks
    January 2016
Posted by badgirl on Friday, January 1, 2016 2:45 PM
Anonymous
BADGER 180-11
HI,
I am trying to sell this compressor on eBay and someone asked me this question.
Do u know if it's gravity feed?
I have been looking all over trying to find the answer and I found this forum. Do you guys know?
I would be grateful for any info you could provide and I am running out of time. Thank you!
