my next airbrush
my next airbrush
Posted by Anonymous on Friday, May 5, 2006 1:07 PM
i already have an Anthem 155,an Omni 4000,and 200 NH,i'm looking for my next AB,i'm a little caught between the Omni5000 and the Sotar20/20...i need something with a smaller cup than the 4000 and i want a finer line when it's called for,,,,,,,anybody have an opinion or suggestion?...
Badger or Theyer Chandler only please,i'm very brand loyal
    May 2003
Posted by DrewH on Friday, May 5, 2006 2:02 PM
I use a badger 155 and 100 fine. the 100 is a fine tip airbrush. My 155 with a fine tip produces just as fine a line as my 100. I mostly use only the 155 now with the exception of small painting jobs. I use the 155 with a fine tip for pre shading and after painting to add exhaust and gun smoke shading. I do all my freehand camoflage with it also. There are smaller cups availible for the 155 as well.
Take this plastic and model it!
Posted by Anonymous on Friday, May 5, 2006 3:27 PM
my 155 is siphon feed,my only current gravity feed is the Omni 4000,that's why i'm looking for another ,but with a smaller cup and finer line capability
Posted by MikeV on Friday, May 5, 2006 7:00 PM
Go for the Sotar, it's the finest line airbrush out there. Wink [;)]
    May 2006
Posted by Brews on Monday, May 8, 2006 3:26 PM
I have a Paasche VL, Badger 100 XF Sidefeed, 155, 150 (with large, medium and fine heads), 360, and an ancient Thayer & Chandler Type A sidefeed.
I bought the two sidefeeds 2nd hand, uncleaned, but with spares. I have no idea of the age of the T&C, but it sprays the finest line of all my brushes, based on a comparison I did the other day with some GS acrylic, at 20psi. I'm not saying I'm not going to use other brushes, but I intend to use the T&C and Badger 100 for enamels, and the others for acrylics, because the T&C and 100 only cost me $25.
My advice would be to look for a 2nd hand, high-quality brush. I suspect (but I may be wrong) that the T&C might have been constructed to finer tolerances than today's brushes.
Posted by Anonymous on Monday, May 8, 2006 4:47 PM
already settled on ,and ready to order the Sotar 20/20,just needed Mike the Badger man to confirm kind of what i already knew and wanted to hear
Posted by MikeV on Monday, May 8, 2006 6:18 PM
I would recommend the medium tip and needle for most work and you can order a fine tip and needle to experiment with but they are small.
Posted by gjek on Monday, May 8, 2006 11:03 PM
Not trying to start an Azteck war but how come I don't read much/anything on the forum about the Sotar? I often see them heavily discounted compared to the MSLP?   Greg
Msgt USMC Ret M48, M60A1, M1A1
Posted by MikeV on Monday, May 8, 2006 11:37 PM
Good question.
I think because people have been programmed to look at Iwata Microns these days is why the Sotar is overlooked. The reason they are discounted so much is because Badger had to put a high price on them so that the consumer would perceive it as a top notch airbrush which it is, but if you list it for half the price of a Micron then the unknowing public perceives it as less of a precision instrument.
