- Member since
March 2006
Posted by NikToo
on Saturday, May 6, 2006 4:41 AM
The nut is the only thing different really, so if you get an airhose with the right size nuts on either end you should be fine. The Eclipse has a 1/8" nut, and I know an Iwata compressor usually has a bigger 1/4" nut (I had to get myself a 1/4" to 1/8" male converter the other day as my airhose has 1/8" in either end). They're quite easy to find, usually hardware stores will have them, otherwise somewhere online near you.
On the bench:
Tamiya 1/48 Tiger I:
Tamiya 1/48 Jagdpanther:
Skybow 1/48 Tiger I Late:
