Problem with Badger 200NH
Posted by PaulusW
on Thursday, May 11, 2006 3:55 PM
Hi Everyone,
I'm new to airbrushing and have a problem with my Badger 200. When the needle is screwed forward (to achieve a bit finer line), a paint stops going through after 10-20 seconds of spraying. If I screw the needle backward and then forward to a desired position, the airbrush starts working again (but only for 10-20 :)). The problem is intermittent and sometimes even occurs with the needle set to "normal" postion. Any suggestions?
Thanks,
Pawel
