Tecs,
I'll try this next time round, i managed to get round my little problem by using an ultra fine grade finishing stick!!
I had let the paint fully cure then lifted all the masks (there was loose paint every where)then it was a case of gently sanding the loose bits off and as the paint was hardened, the finishing stick did not mark or scratch the existing paintwork. finally used an a/brush to blow all the dust and c*** off.
I think once the decals and future/gloss has been applied it will look ok.
Thx for the advice
DT
