I am painting a B36, with different metal shades. All the colors
are gloss MM enamel. I have been using Pactra low tack
masking tape for years with great results. I don't usually use gloss
colors so I 'm new to that. The problem is when I recently took off the
tape on the wing sections there was residue (not really bad) but there.
The paint that was masked over cured for 5 days before taping began.
Is there any solution I can use with a q-tip to remove the residue
without damaging the paint, short of using future. Would alchohol
work???
I don't think I can use this tape again on this plane, and it is very low tack.
Comments appreciated!
p.s. when spraying future how does one thin (ratio) in order to airbrush, and what do you thin with?
