MM Aircraft Gray has a green hue??
Posted by Anonymous on Thursday, May 18, 2006 8:30 AM
    Hey guys I am paining MM Aircraft grey over a white primer, and for some reason it has a bit of a greenish hue.  My airbrush is clean and I have never painted any greenish colors with it.  ANy ideas why this may be happening?
    February 2006
Posted by Wulf on Thursday, May 18, 2006 10:30 AM
Did you mix the "goo" in real well on the bottom of the bottle? You really got to mix MM paints well, especially if they're new. I use a popsicle stick and scrape the pigment goo off the bottom. Do it at each use too.
Andy
Posted by Anonymous on Thursday, May 18, 2006 11:22 AM
 you might be right, because my tamiya paint which is the same color is doing the same thing.  I did not know there was green in the grey.  But hey I am still learning.
