- Member since
Posted by ABARNE
on Sunday, May 21, 2006 3:39 PM
Your problem description is rather vague. Too much splatter sounds like either too much air pressure or overly thinned paint. With my siphon feed airbrushes, I usually spray camo at perhaps 15 PSI give or take. If your airbrush is gravity feed, you would probably want a little less air pressure. Practice on some scrap plastic with different thinning ratios and air-pressure until you can get a clean line.
Andy
