A few weathering questions-
    May 2006
Posted by CarnivourousDonut on Tuesday, May 23, 2006 5:28 PM
It's been decades since I touched an airbrush. Our local hobby shop had a 40% off on airbrushes, so I grabbed a badger (a brand I know)
So far, so good, getting the hang of it.
But a question (or two) here:
I'm doing WW2 tanks. I read about washes, and it sounds good...by hand.
Can it be done via an airbrush?
Lastly, I understand that after painting the tank, but before washing it, it must have a sealant/dullcoat/matt on it.
If this is correct, can said coat be applied via an airbrush, and if so, what brands of coating do you prefer?
Cheers!
Let's rattle the cage, crack the machine. Let 'em know who you are, shine to be seen.
Posted by ipms40049 on Tuesday, May 23, 2006 6:30 PM
i belive I can actually answer this question, but someone can correct me if im wrong. After you paint your model, if your going to use a wash you need to gloss coat it, either with like Testors gloss coat or what I use is future floor polish. Then do your wash over that, its smooth so it will flow into all the right places(hopefully). Sometimes you may need to put a couple good coats on.
Be sure your wash is either acrylic over enamel, or if your base paint on your model is enamel, you can use enamel b ut  use Mineral spirits to thin it down. As for airbrushing a wash, ive never heard of it done, now you can 'dust' the model with like a dirt color, but you need to thin it down alot before airb rushing it and use light mist coats . YOu can also use Pastels as  a wash too and airbrush it. Thin the pastels with denatured alcohol and mix well and shoot through the airbrush.
hope ive gotten it right.
good luck
Pat Hensley Booneville, Ms "Thank you for being here and playing nice"...please do not drag sand outside the box ! CURRENT BUILD(s) Revell 1/72 U Boat VII C Tamiya Willys Jeep - for 2010 Nats Bronco's Staghound -for 2010 Nats Dragons M16 Multi gun carriage - for the 2020 Nats. LOL
    May 2006
Posted by CarnivourousDonut on Wednesday, May 24, 2006 2:34 PM
Why would I use a gloss coat, before I wash it?
    March 2006
Posted by Yann Solo on Wednesday, May 24, 2006 3:23 PM
For the gloss coat, you can apply Future floor finish with your airbrush no problem.  And you can clean your airbrush with Windex (the amonia is the stuff that get rid of the acrylic)
You will need a gloss coat prior to weathering for two reasons:
1. Decals will not stick to flat finish and you must install them before doing the weathering cause those are supposed to be painted on.
2. If you plan to weather a plane, the wash technique is usefull to make these recessed panel lines to be darker and the wash must get into these crevases but must be wipped of the surrounding large areas.  The wash would have a tendency to stay on the flat finish but will be easier to get rid of on a gloss coat.
If you want to build an armor, the wash technique can be done for several reasons ... and it all depends of what results you want.
No matter where you go ....... there you are.
jwb
    February 2006
Posted by jwb on Wednesday, May 24, 2006 3:38 PM
Heed the words of Mr. Solo.
I hadn't built a kit in years, and got back into recently. First one I did was a P-40. When it came time to do the wash for the panel lines, I said "Ah, how much difference can giving it a glosscoat make?"
Not a whole lot, if you don't mind your model looking like vandals with mops spread black paint all over the outer surfaces. :-)
Now- I add a coat of Future, and then use an acrylic wash- 5 parts water, 2 parts dish soap, 1 part acrylic paint(s). Works like a charm.
And I found that if I test a section and the wash is difficult rubbing off- add more soap.
Jon Bius
AgapeModels.com- Modeling with a Higher purpose
"For I know the plans I have for you," declares the Lord, "plans to prosper you and not to harm you, plans to give you hope and a future." ~ Jeremiah 29:11
    May 2006
Posted by CarnivourousDonut on Thursday, May 25, 2006 8:37 AM
So-
After applying the gloss coat, I then do the wash and weathering, and *then* apply a dull coat as final?
Just want to make sure I've got this order right.
    March 2006
Posted by Yann Solo on Thursday, May 25, 2006 8:40 AM
 CarnivourousDonut wrote:
So-
Bullseye!
