"darker" Metallic blue..
Posted by Anonymous on Tuesday, May 30, 2006 10:44 PM
can i mix acrylic Tamiya x-13 metallic blue with x-10 gun metal to acheive a "darker" metallic blue? thanks!
    September 2004
Posted by A Mejias on Wednesday, May 31, 2006 12:42 AM
Sure, why not? You can also try mixing Clear Smoke with Metallic Blue.
Basically you can mix any of the same type and brand paints to get whatever color you like. Start testing with small amounts and keep track of your mixing ratios for later use.
/.\\™ Al Mejias Webmaster "Original Sculptures and Model Kits of the Weird and Fantastic"
    June 2005
Posted by archangel571 on Wednesday, May 31, 2006 1:11 PM
Sign - Ditto [#ditto]
seems to me the gunmetal has a bit of dark dark greyish tone to it, so i'd put another vote on mixing more smoke or even a bit of X-1 since tamiya's metallic blue has a good amount of flakes in it, just gotta make sure you stir it long enough to get an even mix.
-=Ryan=- Too many kits... so little free time. MadDocWorks
Posted by Anonymous on Friday, June 2, 2006 2:15 AM
so the gun metal is not a good choice? i should go with the smoke or black? thanks again guys.
