Hi all
I just got my compressor recently, Werther X1AS which recommends the use of Badger airbrushes.
I use a Badger 360 with the threaded airhose with the airbrush connector on one side and varying source connection on the other (propellant or compressor).
The compressor came with a huge looped vinyl hose with a brass adapter on one end to connect it to the airbrush.
Problem is that the brass adapter adds alot of weight to the brush and makes airbrushing quite uncomfortable.
However when I use the Badger airhose, some air leaks out where the varying connection meets the coompressor.
I think the fact that the varying source connector is smaller than the one on the supplied compressor hose is causing the problem and the propellant connector is getting in the way.
Does Badger sell a threaded air hose with just a single compressor connection on it?
Alternatively could I attach the Badger 1/4 " Adaptor with/Bleed onto the Badger hose and then onto the compressor to prevent the air coming out?
Any assistance would be appreciated.
Thanks
