Will I have damaged my needle?
Posted by Anonymous on Wednesday, June 7, 2006 7:42 AM
    Hi!
I tested my new compressor today by running some air through my airbrush. Only after playing with it for a couple of squirts did I notice that I hadn't taken the cap off the airbrush. Sorry if this is a dumb question, but will this have damaged my needle?
Thanks
Posted by MikeV on Wednesday, June 7, 2006 7:59 AM
No, it should be fine.
    August 2005
Posted by eizzle on Wednesday, June 7, 2006 8:19 PM
When in doubt, take the needle out and roll the end around on the tip of your finger, if its bent you will feel a snag, that or use a Q-tip, it will catch and pull off some of the fibers, both ways will tell you if its bent or not.
Colin
 Homer Simpson for president!!!
    December 2004
Posted by Hippy-Ed on Thursday, June 8, 2006 12:13 AM
 LupoLoopy wrote:
    Hi!
Thanks
I did the same ting when I first got my Badger & thought I might've done some damage but, I didn't. I checked it the same way eizzle had described. I wouldn't worry too much about it. No harm, no foulSmile [:)]
And, the only "dumb Questions" I know of are the ones that aren't askedBig Smile [:D]
If you lose your sense of humor, you've lost everything
Posted by Anonymous on Thursday, June 8, 2006 4:11 AM
Phew!!! Thanks guys. I appreciate it. I checked ti and it's A-OK :D
