Typical first time poster here-1st setup...
Posted by Anonymous on Tuesday, June 13, 2006 3:51 PM
For the past 2 days I've lurked and leeched as much info as I could find.
Intro article on MusicCity, the FAQ's here in this forum, the ABC's of Airbrushing article...various "1st AB" threads, etc etc...   So I hope I've covered the basics.
I will be exclusively painting pewter Warmachine models (generally humanoid in shape and about 30-75mm in height) and probably using only acrylics(Vallejo) .
I hope that (after months for practice, profanity and patience) I can achieve the ability to lay down a smooth, thin basecoat, do some moderate blending and maybe even generate some of those 1/32-1/16 fine lines that I've read so much about. A realistic expectation?
So based on its simplicity (generalized one needle/tip, ease of disassembly)  I'll shoot for a TC Omni 4000 and an AB Depot TC-20T compressor with tank, reg and water trap (Yes, I know the air tanks are quieter/cleaner/better, but intital outlay is set at an introductory level).
One question I had that was only briefly addressed in the intro material was ventilation.  I'm a garage guy, but mine has no windows or vent ports.  On days when I can't open the main garage door(occurs often in rainy Oregon), am I going to generate a lethal noxious cloud that will eventually claim my health? Using a low PSI, with only water thinned acrylics, on such a small "canvass"....?    Is the respirator/spray booth a health necessity?
Oh, and Thank You for all the info.  It's helped a great deal.
    May 2005
Posted by Bgrigg on Tuesday, June 13, 2006 5:00 PM
If you can't ventilate, you are running a health hazard! Check out a respirator at the very least (not those coffee filter face masks, they won't help much) if you can't afford or build your own spray booth. Even if you only spray acrylics you run the risk of sucking in microscopic particles of acrylic, which is a plastic.
So long folks!
Posted by jhande on Thursday, June 15, 2006 7:18 AM
It really wouldn't be that difficult to get ventilation into the garage for your model spraying area.
Pickup one of those through the wall clothes dryer vents. You can make a small inexpensive wooden box spray booth out of pine boards from the lumber yard or Home Depot. If the opening in the front of the box isn't too large, and the vent is short and straight out the back, then you can get away with a fairly cheap exhaust blower. Especially since you are not spraying anything with highly explosive fumes.
When it comes to ones health, better safe than sorry.
-- Jim --
"Put the pedal down & shake the ground!"
