what exacly does this stuff do ???
    November 2003
Posted by rudedog on Thursday, June 15, 2006 2:36 PM
While perusing my LHS,I spotted Gunze Sangyo Mr.surfacer 500 & 1000.I've heard many of you In this magazine,Et al mention it.The instructions are japanese.Is it a buffing polish ?If so is it like sandpaper,lower the coarser, the higher of abrasive property's ? Do you apply it similar to car wax ?Thanks much ahead.   rudedog
"...That's an order,not a debate topic , Sergeant Rudzik..."
jwb
    February 2006
Posted by jwb on Thursday, June 15, 2006 2:52 PM
I've never used those products, but if you go over to this page on Swanny's Models, it goes over them fairly well.
Hope it helps! I use that site a lot myself!
Jon Bius
AgapeModels.com- Modeling with a Higher purpose
"For I know the plans I have for you," declares the Lord, "plans to prosper you and not to harm you, plans to give you hope and a future." ~ Jeremiah 29:11
Posted by ABARNE on Friday, June 16, 2006 1:22 PM
Mr. Surfacer is basically like thinned putty.  You can spray it to fill in sanding scratches on a large area, use a small brush to precisely fill in minor seams.  You can also texture the stuff to simulate cast iron, non-skid surfaces and what not.  You thin it with lacquer thinner.  I don't use it a whole lot, but having a jar around can be mighty handy for those types of situations.
Andy
    September 2005
Posted by TB6088 on Saturday, June 17, 2006 12:39 AM
I've used Mr. Surfacer as a primer coat thinned 1:1 with laquer thinner with pretty good results.  It seems to provide a really good surface for accepting the acrylic paint I use.
TomB
    November 2003
Posted by rudedog on Tuesday, June 20, 2006 8:55 AM
Thanks all of you.The Swanny's  article was particular inciteful.  Semper fi,  rudedog
    May 2003
Posted by DrCemento on Monday, June 26, 2006 8:46 PM
save for massive gaps I use all three -500,1000,1200 almost exclusinvely as my filler- primers - its brushability gives un-parralled control in  tight spots - build it up in layers for larger areas - you'll find yourself sanding allot less . It dries  quik,  is not brittle can be scribed what more can you ask for (just don't use the 500 as a primer!)
Model builder formerly posting as jbatesc6
