- Member since
Posted by ABARNE
on Friday, June 16, 2006 1:16 PM
I have to ditto Ross's advice. I have had different bottles of identical colors of the same brand require different thinning ratios, so the concept of a hard and fast thinning ratio really doesn't work. I have even had paint which was perfect for airbrushing straight from the bottle. The main thing, particularly as you are getting used to what properly thinned paint looks like, is to practice on a non porous surface, hence the plastic milk jug suggestion, prior to painting on your model. The reason for using a non-porous surface when testing is that if you spray on something like paper, the paper could easily absorb a lot of excess thinner that would pool up if sprayed on plastic. A majority of your early airbrushing success or lack thereof will be directly attributable to getting your paint to the proper consistency.
Andy
