Future vs. Decals... what am I doing wrong?
    August 2005
Posted by eizzle on Saturday, June 17, 2006 10:30 PM
The last layer of gloss Future seems to be giving me problems! On the last two builds I have done, both times my decals wrinkled when I applide the last coat! My questiong is this, am I doing something wrong, or did I not let the decals sit long enough? They were there for over 5 days and I am not thinning my future with anything? Thanks in advance gentlemen!
Colin
 Homer Simpson for president!!!
Posted by Anonymous on Saturday, June 17, 2006 11:02 PM
i usually coat it with future and let it dry,right before applying the decal i brush some on that spot and set the decal in place while it's still wet,that helps it adhere and stops silvering at the same time,,,if it lays down good in 20 minutes or so i brush another coat on the decal at that time,,,,after all that has dried for a day,i spray the final coat,hope that helps out
Posted by ABARNE on Sunday, June 18, 2006 12:33 AM
I usually shoot future straight from the bottle, and my decals don't wrinkle so I don't think that's the problem.  I typically wait only a day after applying decals before overcoating so I don't that's the prob;em either.  After your decals have completely set, do you wipe them and the surrounding areas with a damp cloth to remove any setting solution residue?  If not, perhaps some remaining setting soultiom residue is being re-activated by the Future.
Andy
    August 2005
Posted by eizzle on Sunday, June 18, 2006 7:30 AM
You could be right about the setting solution, I got in a hurry and didn't do anything but dust it Disapprove [V] I haen't had a chance to look at it this morning, hopefully the big decals have settled... hopefully! Thanks for the help guys.
Colin
    January 2003
Posted by Triarius on Sunday, June 18, 2006 10:35 AM
Andy's basically got it, I think. Future is an acrylic coating similar to acrylic paints. All paint coatings shrink, at least slightly. Future shrinks less than most, but still shrinks. The decal or decal adhesive serves as a bond-breaker between the two coats of Future, and it is especially bad if you leave dried setting solution on the decal surface. When the Future cures, the portion over the decal is not restrained by bonding to the Future beneath it, and the slight shrinkage causes wrinkling or cracking of the decal.
It is always wisest to clean a surface immediately before coating.
    August 2005
Posted by eizzle on Sunday, June 18, 2006 5:58 PM
Ok, I finally got to take a good look at it and most of the decals settled down a bit, there are a couple airbubbles, but I can handle those. So what do you guys recommend to clean it with? I was afraid to use water because I didn't want the decals to come loose, and I was afraid anything else might damage them?
Colin
    January 2003
Posted by Triarius on Sunday, June 18, 2006 6:28 PM
For cleaning before painting, there are two things you can do:
  1. Don't let it get dirty in the first place. Put it in a container when it's idle. I use a large, plastic, covered cake tray.
  2. Wipe it down with a damp cloth—basically you are dusting. If you are worried about skin oil or something like that, use a little vinegar on the rag. Don't scrub, just wipe.
    August 2005
Posted by eizzle on Sunday, June 18, 2006 7:38 PM
Thank you Ross, I was worried about the decals, its a $150 kit and its all most done, so ruining the decals now would be very, very bad to my motivation Big Smile [:D] I just got in to much of a hurry last night and wanted to get the Future coat on so I could do the panel lines. Again, thank you gentlemen!
Colin
    October 2005
Posted by gulfstreamV on Sunday, June 18, 2006 8:43 PM
Same thing happened to me. Did not give each coat enough time to "cure", the paint and future shrank/dried and the decals lost the battle. Not so good at the end of a build..................Cool [8D]
Stay XX Thirsty, My Fellow Modelers.
    August 2005
Posted by eizzle on Sunday, June 18, 2006 9:28 PM
Its such a pain isn't it? I hate it when I mess up towards the end, but sometimes if its at the begining of the build it really kills it for me.
Colin
    January 2003
Posted by Triarius on Sunday, June 18, 2006 10:13 PM
I didn't mention (thought it was obvious, but maybe not) if you used vinegar in the wash, wipe a second time with water only.
    August 2005
Posted by eizzle on Monday, June 19, 2006 6:41 AM
Noted Ross, thank you. It probably is obvious, but when I get in a hurry, I'm pretty oblivious Big Smile [:D]
Colin
    January 2003
Posted by Triarius on Monday, June 19, 2006 10:50 AM
Obvious or oblivious…whatever…  Laugh [(-D]
