ch-53 hydrualic leaks
    May 2003
Posted by centerdeck on Tuesday, June 20, 2006 11:45 AM
I am about to purchase MRC's 53 and had a question for a technique on simulating the pool of hydrualic fluid that always appears on the deck under the rotor (if you ever have to ride in one, try to sit in the back).  I have already been messing around with a couple that I thought would work, but they just don't look right.  I tried various shades of red with  gloss coats applied after drying, but they end up looking like a poor rendition of a failed blood pool.  I am shooting for a more opaque but mixing the red with the gloss wasn't working either.  Normally I don't attempt these kinds of details, but what I remember most about riding in these was the crew chief telling me "If it ain't leaking, get off cause it won't be going far".
    July 2004
Posted by tho9900 on Tuesday, June 20, 2006 6:41 PM
ahhh the memories!!!  I remember a very long medevac on a 53 I did... about mid flight I was talking to the doctor with me and looking at the patient, when I could have sworn something was on my back.. I started slapping at my back and the crew chief laughed and told me that it was hydraulic fluid dripping on me, and it was normal... he said if I noticed it stop leaking to let him know, he wanted to be the first out the door...
Have you thought about oils for the hydraulic fluid?  I would imagine a burnt siena and paynes black mixture would look pretty good, plus they stay wet a lot longer than other paints and are "workable"... i.e. you can still spread them and blend them for a loooong time, giving you time to find "just the right look"  I might play with that this weekend as I wouldn't mind doing a 53 and a 46 myself one day... put them on my shelf to remind me of "the good old days"  and like you, I would want to get it authentic Wink [;)]
  • From: Modeling anything with "MARINES" on the side.
Posted by AH1Wsnake on Tuesday, June 20, 2006 8:06 PM
Have you tried using the Tamiya line of 'clear' acrylics? They should provide the opaque look you are going for; try a mix of clear red and clear yellow.
"There are only two kinds of people that understand Marines: Marines and those who have met them in battle. Everyone else has a second-hand opinion."
    July 2004
Posted by tho9900 on Tuesday, June 20, 2006 8:11 PM
That's what I was trying to think of!  I knew there was a line of paint out there with a bit of   translucency like an oil based product... I just couldn't remember what it was I was trying to think of... good idea!
    May 2003
Posted by centerdeck on Tuesday, June 20, 2006 11:26 PM
I guess I'll have to order those online.  I got the bullfrog (louder but cleaner) already, but I will probably upgrade the airbrush before I build it.  Thanks for the tip.
Posted by AH1Wsnake on Wednesday, June 21, 2006 12:20 AM
Also, you can use the clear green to airbrush onto the canopy overhead panels for their tinting, and the clear smoke can be airbrushed in light coats to simulate exhaust weathering. I use Tamiya's clear colors for all sorts of lenses and displays on various vehicles. Good stuff.
    January 2005
Posted by peglegrc on Wednesday, June 21, 2006 4:20 AM
Also you can use the "Candie" Color's too... red or green, blue, purple... etc.. what ever color the fluid is, the candie  is clear and shinny and stays that way......[}:)
        "RC"
PeglegRC "The Meaning of life??? How the Heck should I know? Try Google." "Can You Expand your report about Employee Morale?..I'm Afraid 'Bite Me' doesn't Quite cover it"... "Please excuse any misspelled word's!
Posted by Anonymous on Wednesday, June 21, 2006 8:57 AM
i bet if you mix clear red and clear green, it'll make that weird hydrolic fluid color.  you could also try using clear amber (intended for turn signals) that i know they make and maybe change the color by adding a little smoke.  you could also use a thinned translucent sepia ink.
me and some people went inside a ch-53 when they brought it in for maintenance or just for show to the plant.  I was wondering about those hydrolic leaks.  buddy of mine got dripped on.
Posted by berny13 on Wednesday, June 21, 2006 3:53 PM
Hydraulic fluid wasn't red.  It was more a reddish pink.  Take gloss pink and add gloss red to it until you get the color you are looking for.  Then use a clear to thin it out so it will spread.  That is what I used several years ago on a diorama I built.
Berny
 Phormer Phantom Phixer
On the bench
