Luftwaffe Mottle Help
Posted by Anonymous on Thursday, June 29, 2006 3:36 AM
Morning to one and all
Well its time to tackle this head on , I ve just about got the hang of my airbrush , by just about I mean  the cat is almost back to its original colour Smile [:)] and no matter what the wife says the wall looks better with the splinter pattern.
I model in 1:72 and am about to tackle some WW2 German fighters Bf-109s & FW-190s I intend to use xtrarylics , which apart from drying a bit quickly in the brush have served my well , now heres my problem , I cant control the brush well enough yet (ever hopeful) to mottle ( I have a practice plastic bottle that has every camo scheme in history) I ve been told that at 1:72 its nigh on impossible to do right & I d be better of using make up sponges with minuit touches of paint on them!!!! now I remember tearing apart one of my mums sponges when I was 10 to do this kinda thing on a desert camo Bf-109 and lets just say as a applicator it made one hell of a spongeBig Smile [:D]
So what you think , do I keep practicing on my coke bottle ? , sacrifice a fighter to the god of paint mistakes ? move up to 1:48 ? or stick to the allies planes
    April 2005
Posted by T_Terrific on Thursday, June 29, 2006 10:32 AM
With the direction you seem to be going, since you are using a non-toxic acrylic; you might try one of these techniques:
  1. Siphoning the color you want with a soda straw, put the filled straw up to your mouth and have someone tell you a bad joke, so you spray it out in blotches all over the model in question. The trouble with this method is that you have to do it more then once for each side you need to paint, and you can get overlapping mottles. Whistling [:-^]
  2. If that doesn't work, you can make tiny slippers for your pet centipede, and have him dip his tiny feet in the paint, and have him walk all over your subject. The trouble with this method is now and then your pet might slip and simply smear the paint, and may not be patient about the occasional renewing of the paint on his tiny slippers. Clown [:o)]
  3. Otherwise you can try making a template out of some of the masking film they sell these days, lay it down on the subject and paint over the irregular holes you have carved into it. With this method, either bristle or air brushing can be used.
In any case, you can always paint over the excess blotches with the other colors you want the plane to be.
Other then the above, I dunno Confused [%-)]
  Tom T Cowboy [C):-)]
Tom TCowboy
“Failure is the opportunity to begin again more intelligently.”-Henry Ford
"Except in the fundamentals, think and let think"- J. Wesley
"I am impatient with stupidity, my people have learned to live without it"-Klaatu: "The Day the Earth Stood Still"
"All my men believe in God, they are ordered to"-Adolph Hitler
    October 2004
Posted by paul_toz on Thursday, June 29, 2006 11:27 AM
Hi Zomok,
there is an easy way to do this although it might be considered cheating - brass etch paint masks. Both Eduard and Airwaves make them in all the usual scales. Airwaves do a generic 1/72 one, part number AEMM501 or something close to that and Hannants have it at £3.99 at the moment.
Regards
Paul
jwb
    February 2006
Posted by jwb on Thursday, June 29, 2006 2:52 PM
While certainly not wanting to contradict Tom's methods Wink [;)], I'd thought about something as simple as a notecard. Cut a small hole in it, near the center, and hold it over the model. Airbrush the card, some paint slips through, and you get a small dot with a fuzzy edge. You just keep moving the card around, building up different patterns. You probably would have to change cards, but it would be a cheap and simple thing to try.
Probably could use pieces of the kit box. Big Smile [:D]
Never tried it, but I swear I read it in an article in FSM.
Jon Bius
AgapeModels.com- Modeling with a Higher purpose
"For I know the plans I have for you," declares the Lord, "plans to prosper you and not to harm you, plans to give you hope and a future." ~ Jeremiah 29:11
Posted by espins1 on Thursday, June 29, 2006 2:56 PM
I'm actually going to try that technique on my 1/48 Me-109E-7 (about 70% complete).  I was planning using several cards so there wouldn't be a patter, and put randomly shaped and sized holes in the cards.  I'll hold the cards a bit away from the surface, which should make for a nice fuzzy edge.
Scott Espin - IPMS Reno High Rollers  Geeked My Reviews
    May 2006
Posted by Dave23 on Thursday, June 29, 2006 4:05 PM
That's the way I did it many, many years ago. It does work, just have to play with distance from the subject to get it just right.
I also see that you can now buy pre-cut mottle and splinter masks.
-dave
-d
