I'm very inexperienced with camo patterns and need help
    July 2003
Posted by MonsterZero on Sunday, July 2, 2006 11:18 PM
Click the link and take a look at this 1/48 kit. I'm building the very same model but have problems with airbrushing a similar pattern. I tried shooting through an index card with a circular hole in it but it looks horrible. Because you can't actually see the pattern as you spray (the card cover it) any attempt at making the mottles prettier only make it worse. The card is blown by air pressure towards the model so you can't control the distance between the card and the kit either. It makes me scream.
Can I shoot such mottles freehand with my Badger 155 Anthem?
What do you think?
http://www.kitparade.com/features00/ta154ck_1.htm
    October 2005
Posted by gulfstreamV on Sunday, July 2, 2006 11:43 PM
I think you can,   It's that practice thing. Steady freehand control. Fine adj's to the AB and paint mix so very little paint is being sprayed..and take it slow.......It's like hitting a home run or a goooaal! when you 'get it" so to speak. Good luck, I'm sill trying and seem to be my worst enemy, trying to be too perfect and not getting anything done.........Oh well, nothing like a challange.........Cool [8D]
Stay XX Thirsty, My Fellow Modelers.
    July 2003
Posted by MonsterZero on Monday, July 3, 2006 3:09 AM
I found this online, check it out:
When using Model Master enamels, and you want a fine line without overspray, try mixing 2 parts paint, 1 part lacquer thinner and a touch of clear gloss enamel. (from Pete Peterson)
I use MM enamels so I will try out this technique at once. If this for some reason fails to work the next stop is Blu Tac compound.
Posted by MikeV on Monday, July 3, 2006 3:13 AM
Fine lines without overspray?
What is that guy smoking? Laugh [(-D]
    January 2004
Posted by MusicCity on Monday, July 3, 2006 5:12 AM
I have to agree with Mike.  The whole reason for using an airbrush in the first place (ok, one of them!) is to GET the overspray which creates a soft blend between adjacent colors.  If you don't want any overspray, just mask the areas.
Can the 155 spray patterns like that? Yes, it can.  Can you do it?  I don't know, only you can answer that.  Spraying fine-lines with an airbrush is the single most difficult thing to do with one.  It is not an ability that is included in the box with the airbrush, and the only way to master it is practice, practice, and then some more practice.  Practice on old milk bottles until you get the pattern that you like.  The paint viscosity (how thin it is), air pressure, and distance from the model all affect how it works.  YOU will have to find a combination that works for you.  Try what others suggest, but if it doesn't work for you look for a different way.
For fine lines I thin my paint 1:1, lower the air pressure down to about 8 psi, and get about 1/4" from the surface of the model.   I also angle the airbrush so that most of the overspray will go into the color that I am painting.  This is what works for me, but others do it differently.
    May 2005
Posted by Bgrigg on Monday, July 3, 2006 11:06 AM
You mean I can stop looking in the box? What a relief!! People were giving me funny looks as I held the box over my head, shaking it and muttering darkly...
Silly Putty (found in the toy section) is a great method of masking. Here's an article I found Googling "using silly putty for masking" and lo and behold, it's a Finescale article!
http://www.finescale.com/fsm/objects/pdf/sillyputtymasking.pdf
Good Luck!
So long folks!
    August 2005
Posted by eizzle on Monday, July 3, 2006 11:01 PM
If your going to go the silly putty route, keep in mind that if you leave it on to long it will stain your paint job. A technique I use is to roll up masking tape and use that to hold the edge of your mask off the model, and its adjustable, its the same effect, just without the risk of the staining. Good luck!
Colin
 Homer Simpson for president!!!
