sequence in painting ?
Posted by Anonymous on Wednesday, July 5, 2006 3:39 AM
i'm new in modeling,
can anyone tell me what the sequence of painting ?
Posted by ajlafleche on Wednesday, July 5, 2006 10:45 AM
Insufficient data.
What are you painting? What effect are you trying to achieve? What kind/brand of paint? Do you have an airbrush? Are you using brushes or an aerosol can?
Point to a picture of where you want to go with your painting and you'll get a more specific answer.
Posted by jhande on Wednesday, July 5, 2006 2:52 PM
I have to agree, insufficient data, kind of a broad generalized non-specific question.
But maybe these will help if this is what you meant?
BMC :: The Basics of Spray Painting
BMC :: How To Lay Down A Perfect Paint Job
BMC :: How to Paint Window Frames and Rubbers
ScaleWiki : Painting Tutorials
-- Jim --
"Put the pedal down & shake the ground!"
i want to paint paint car model
Posted by Anonymous on Wednesday, July 5, 2006 11:59 PM
sory for the insufitient data
i want to paint a car model like enzo ferrari
i want to know the basic step.
do i need to apply varnish ?
when must i apply it ? after decaling or before ?
thank u
Posted by ajlafleche on Thursday, July 6, 2006 7:32 AM
Okay, that's better!
Prime the model. Apply multilpe light coats of the body color, lightly sanding with extra fine, no less than 1000 grit, sand paper between coats. Each coat should have more thinner in the mix. Pick up some polishing pads at the LHS for the final coat. While you're there, pick up some carnuba way and apply it like you would on a real car, buffing after it dries. You may want to seal the decals and apply a caot of clear gloss over them before the wax.
