MortarMagnet wrote: |
Hey Will, FS34087 is the proper color. I don't want to confuse you. That M5A1 of mine is painted FS34087 with some touch up done with XF-62. I put that up so you can see the difference... which isn't that great as you can see. Someone bite my head off if I'm wrong, but I think that 62 is based on FS24087 which was the color OD used MidWW2 by the US. It is slightly less brown if you will, Will. Like I said, if you aren't trying to make it 100% and you can live with it, it should be fine.
MM - the only diff between those two colors is one is matte and one is semi gloss. The first digit of a FS color just denotes its' sheen.. 1 = gloss, 2 = semi gloss and 3 = matte or flat.
XF62 cross references to 34087 according to the charts... I haven't messed with Tamiya in so long I couldn't tell ya which is right to be honest... I've been using Vallejo for awhile which usually is pretty close...
Will - My take is if it looks too green lighten it with tan or yellow. (yellow would probably work better.) Basically if you're happy then don't worry about it... I think if it is too green to you, after you weather it you might change your mind... weathering fades out things a lot..
