Large areas with brush - how?
Posted by Anonymous on Monday, July 10, 2006 5:33 AM
There may be more of these posts in here but I couldn't find one, so if this is the case I'm sorry for posting this...
So, I have a Revell Corvette C6 and I need some help with the bodywork. Since I don't have airbrush I have to do this with a normal brush. How should it be done so that the surface would look smooth?
Or should I just go and buy some cheap airbrush and a few cans of air?? (later on I might get the Tamiya's 1/350 Bismarck so will some cheap airbrush gonna help me paint that thing or should I get some pro brush (damn expensive) straightaway?)
    March 2006
Posted by Dubau on Monday, July 10, 2006 7:27 AM
You talk about brushing on the paint and maybe getting a A/B latter on. Why not for now get some spray cans to get the job done ?
Just a thought
Bud
" You've experienced a set back, and without set backs and learning how to fix them you'll never make the leap from kit builder to modeler "
Posted by jhande on Monday, July 10, 2006 10:34 AM
I'd have to side with Bud, why not a few spray cans of paint?
IMHO:
If you have to ask how to get a smooth brushed finish, it won't happen right away, especially on a car body. But a few tips - use a good quality brush, keep the brush wet, long smooth strokes, and hopefully the paint will level out. More than likely, followed by lot's of careful wet sanding and rubbing out.
A cheap airbrush? Well, I would suggest an inexpensive AB but of good guality. As far as an air supply, I would really consider other alternatives to the canned air as they can effect your spraying.
I think what you should do is consider how much modeling you plan to do. Start with some spray cans and get used to the feel of spraying. Some very nice finishes can be accomplished with spray cans. Do some searching here on the forum for such info as AB's and air supplies (i.e. - canned air, compressors, CO2 tanks, air tanks, etc...). Armed with that information you can decide on an AB which you can get for as cheap as $40.00 and still be of good quality (I just bought one for $20.00 on sale). If you can't afford a compressor or CO2 tank right away, you could get one of those air tanks meant for filling tires. That just means a trip to the corner gas station (or wherever has an air pump/compressor) for refilling.
Just my  My 2 cents [2c]
-- Jim --
"Put the pedal down & shake the ground!"
    February 2006
Posted by Wulf on Monday, July 10, 2006 11:13 AM
Sign - Ditto [#ditto]
Give the rattlecans a shot. I did at first and worked my way to the AB. Much better than hand brush.
Andy
Posted by Anonymous on Monday, July 10, 2006 12:21 PM
Thank's for your answers! Well I had few spray cans and the result with them was awful. So I bought Aztek A470 airbrush and a little compressor. Hopefully this works out... Back to practicing =D
    March 2006
Posted by Dubau on Monday, July 10, 2006 12:45 PM
Skipwankman, let us know how you make out.
Bud
Posted by Anonymous on Tuesday, July 11, 2006 3:49 AM
This is way harder than I thought Oops [oops] After my first try on the Corvette's bodywork I had to give it a quick bath and scrub out that crappy paintjob... Luckily I was using water based paint Smile [:)]
Second time things went a little better. Overall quality was pretty smooth. Though I had some difficulties finding the right distance and pressure/feed. Also I think I used too thin paint mix, about 40% water and since I was painting with yellow that might not have been the best idea... Ashamed [*^_^*]
When I was almost finished I started to have problems with water mixing into compressed air since I don't have moisture trap yet. So next time I go to my hardware store I gotta get one Big Smile [:D]
But since this was my first time ever using airbrush I'm quite happy with the result! I was expecting something much, much, much worse...
EDIT: Oh yea, I also need to fix that tube coming out of the compressor. Damn thing popped out just before I had the chance to turn the compressor off...Angry [:(!]
Posted by Anonymous on Tuesday, July 11, 2006 5:44 AM
Btw, should I undercoat parts before using AB? For example car body, is is necessary to undercoat it first or does the AB do the trick? What I'm trying to say here is that should I AB the body with really thin coat and then let it dry for a longer period of time before giving it another coat or is the result as good if I just start laying several coats on eachother while they're still a bit wet?
Really appreciate your help guys. Just getting started with this AB thing Smile [:)]
    March 2006
Posted by Dubau on Tuesday, July 11, 2006 7:44 AM
As for all the miss haps you had NP we ALL had them. Get a Mos Trap. and Yes I would spray an under coat.
Lets see some pics too :)
Bud
Posted by Anonymous on Tuesday, July 11, 2006 8:07 AM
Pics?! Er... Blush [:I]
Maybe some day.. when it's finished perhaps... Big Smile [:D]
    March 2006
Posted by Dubau on Tuesday, July 11, 2006 8:23 AM
That's cool, But want to see some Thumbs Up [tup]
Bud
Posted by Anonymous on Wednesday, July 12, 2006 5:36 AM
Well here's some pics as you requested... They show mainly two things, I don't know how to paint nor how to take good pics Big Smile [:D]
http://i56.photobucket.com/albums/g199/Skipwankman/89240027.jpg
http://i56.photobucket.com/albums/g199/Skipwankman/6fd733e9.jpg
http://i56.photobucket.com/albums/g199/Skipwankman/3d47a7fa.jpg
    March 2006
Posted by Dubau on Wednesday, July 12, 2006 8:09 AM
Keep it up, looks good so for
Bud
    February 2006
Posted by Wilbur Wright on Wednesday, July 12, 2006 4:19 PM
In General good brushes like Windsor and Newton purchased at an art store are a must for the serious modeler. Pearl Paint is where I get mine. If you go and spend fifty bucks on quality brushes yopu will never regret it, and they will last, as well.
    June 2006
Posted by MaxPower on Wednesday, July 12, 2006 9:29 PM
jhande posted this the other day. I dug it up because I think it's exactly what you're looking for. Hope it helps you. :)
http://www.briansmodelcars.com/tutorials/tutorial.asp?TutorialID=12&CurPage=1http:/
Posted by Anonymous on Friday, July 14, 2006 2:36 AM
Wow! That's an excellent page! It had some good techniques that will surely help me with my model.
Thanks Max!
    May 2006
Posted by MortarMagnet on Friday, July 14, 2006 6:04 PM
I just experimented with using a brush and an emery board to simulate a caste texture... it looks pretty good, but my crappy camera isn't good enough to show the detail.Sad [:(]  I don't think they caste Corvette fenders.Smile [:)]
Brian
    November 2004
Posted by PanzerWulff on Sunday, July 16, 2006 6:51 PM
one nice item to have is a clean primed PLASTIC MILK JUG ( HUH you say is this guy WHACKO?Confused [%-)] ) A plastic milk jug is a great item to practice technique on so you're not blasting away on a model g\saying "Hmmmm I wonder if THIS will work. Nope SCRUB SCRUB SCRUB"Big Smile [:D]Wink [;)]
ACE??? you were NEVER an ace AN ace HOLE maybe! (Lister to Rimmer on BBC's RED DWARF) Chris"Hey GRAVITY still works"Gray
    July 2004
Posted by tho9900 on Sunday, July 16, 2006 7:35 PM
yup!  me and my milkjug are on a first name basis!  I just use a can of Krylon primer and primer over it when it is full.  Anytime I come across something new I haven't tried yet, I do it on the milk jug first... get it right, then put it on the model!!!
Posted by jhande on Tuesday, July 18, 2006 8:40 AM
A word of caution regarding the milk jug for practicing on.
Wait until the family is done drinking the milk.  Wink [;)]
My kids thought it was cool, the wife on the other hand... Black Eye [B)]
Thumbs Up [tup]
-- Jim --
