Primers
Primers
Posted by Anonymous on Tuesday, July 11, 2006 6:49 PM
I have a kit with a few PE parts and want to save money on primers for future use, do I really need a metal surface primer or will a general hobby primer cover all my moddeling needs? (white metal, PE.....)
Thanks
Will
    July 2004
Posted by tho9900 on Tuesday, July 11, 2006 7:31 PM
something like Krylon white primer should work fine, it's mostly what I use.  if you are painting a dark color over it, one of the red or dark gray auto primers would work as well...
Posted by ABARNE on Tuesday, July 11, 2006 11:47 PM
I've never used primer over PE and have not had any problems, so I would assume that a general primer would work fine.
    May 2006
Posted by MortarMagnet on Tuesday, July 11, 2006 11:54 PM
Sometimes primer helps.  Color tone can vary if you don't prime, but with PE it doesn't matter as much.  If you had an Al barrel and Resin/pastic mixed, I would prime it.  Test out whatever primer you do pick.  Some can be think and you might lose detail.
Brian
Posted by Anonymous on Wednesday, July 12, 2006 5:41 AM
Oh, I was under the impression it was advisable to prime PE, thanks guys I dony have to bother now.
Will
    August 2005
Posted by Phil_H on Wednesday, July 12, 2006 6:11 AM
Will
There are a couple of things you can do to help ensure your paint sticks to PE/metal parts. (1) PE parts tend to be very smooth, sometimes polished. For PE parts which aren't "textured" by the etching process, you can very lightly rub them with fine (1200 or higher) grit wet and dry to "key" the parts to help the paint stick. (2) The other thing is to wash the parts with alcohol (or metho here in Aus) before painting.
    May 2006
Posted by MortarMagnet on Wednesday, July 12, 2006 8:32 AM
That also removes all the oils from your fingers, which IMO, is even worse for painting over than the extemely smooth surfaces.
Brian
Posted by Anonymous on Wednesday, July 12, 2006 6:45 PM
Ok, thanks
Will
