AB hose - Brand/Quality... ?
Posted by jhande on Wednesday, July 12, 2006 7:51 PM
I don't remember seeing this topic brought up before, if it was... forgive me.
I'm looking to get another AB hose, probably the braided type.
What I'm going to do with it is snip the end off and attach a female quick disconnect (Createx I guess).
Then on my Thayer & Chandler, and Iwata attach a male quick disconnect.
Before I decide how I'm going to permanently hook-up my spray area (length I need), I was looking at some hose options at Dixie Art.
Here's where my question(s) comes in with my confussion... Confused [%-)]
Is there a difference in quality between the brands of air hoses?
Or is it just a price difference because of the names?
From Dixie Art:
Paasche 10' $ 9.50
Badger   10' $13.95
Iwata       10' $18.95
I don't mind spending extra money if the quality is better and the hose is easier (lighter/more flexible) to work with and last longer. But not if it's just because of the name associated with it.
-- Jim --
"Put the pedal down & shake the ground!"
Posted by Anonymous on Wednesday, July 12, 2006 8:33 PM
i haven't had experience with the others,but i do have several Badger hoses and never a problem,very well constructed and flexible,,,my main hose is about 16 years old and i see no need to order a replacement
    July 2004
Posted by tho9900 on Wednesday, July 12, 2006 8:52 PM
to be honest I own both Badger and Iwata hoses and don't note a visible difference in them beyond color... someone else might be able to offer you more but to me they appear the same...
I paid less than dixieart for the Iwata by using a 40% off Hobby Lobby coupon.  (they sell Iwata now too) if you have one in the area they have a 40% off coupon on their website this week good till Sat..   the only Paasche hose I saw there was the plastic kind (I think)
    January 2003
Posted by Triarius on Wednesday, July 12, 2006 9:00 PM
I got a Badger hose with the T&C I bought recently. I found it to be less flexible than the Paasche hose I already had, and which has served very well for over twenty years. I do not know if current issue Paasche hoses are as good as the one I have
Posted by jhande on Wednesday, July 12, 2006 11:38 PM
Thanks for the input guys.
I had a few bad experiences with an airhose for my large compressor. Not that I bought a "cheap" hose, but a different brand from a department store instead of the more expensive from the part store. Needless to say it was a waist of money because it didn't last long.
No Hobby Lobby anywhere near me.
I have a couple of things to order from Dixie Art so the hose will help make my free shipping. Wink [;)]
-- Jim --
    January 2004
Posted by MusicCity on Thursday, July 13, 2006 5:21 AM
Call me weird but personally I prefer the cheap vinyl hoses over the braided kind.  I have a couple of the braided hoses and never use them.  I use one of the old vinyl hoses I've had for about 12 years simply because it is so much more flexible and the smaller diameter gets in the way less.
Posted by jhande on Thursday, July 13, 2006 6:38 AM
Thanks Scott, make's sense and I didn't realize they would last that long.
I wonder now... will a quick disconnect fit on one?
-- Jim --
    January 2004
Posted by MusicCity on Thursday, July 13, 2006 8:10 PM
Jim, they do last quite well, however I admit I have a minor leak around one of the hose fittings.  I guess that's to be expected after this many years though.  It isn't bad and I usually just unplug the airbrush when I'm not using it.  Even if I forget it isn't a big deal since I have a 15 gallon tank on my compressor ;)
Probably not, but I don't know for sure.  All I use is standard 1/4" NPT quick disconnect fittings.  The vinyl hoses have little bitty threads.  Both ends are the same size as those of the air valve on the airbrush.  The 50-023 adapter (About halfway down This Page) is necessary to get it to fit a 1/4" NPT fitting.
    May 2005
Posted by Bgrigg on Thursday, July 13, 2006 10:23 PM
I had a braided hose and found it very heavy.
So long folks!
Posted by jhande on Saturday, July 15, 2006 1:58 PM
Thanks again Scott and thank you too Bill.
I was thinking of running the vinyl hose (came with compressor) up to an AB/regulator holder and then a 6' or 8' braided hose (thought it would handle the abuse better) with a quick disconnect. That way I could switch between AB brands easily. I'm trying to have it setup so I can have my paint booth on one side of the workbench and my wife can spray her stuff on the other side (not at the same time though LOL).
Maybe I should just concider a manifold and have short vinyl hoses running to each AB... humm? But then I'll be getting a few more AB's and also want to be able to work at the hobby bench or out in the garage on larger projects.
Still contemplating this hook-up for ease of use and mobility.  Banged Head [banghead]
-- Jim --
    August 2003
Posted by bilbirk on Saturday, July 15, 2006 4:26 PM
Sign - Ditto [#ditto]
Posted by jhande on Saturday, July 15, 2006 6:57 PM
Thanks  Thumbs Up [tup]
-- Jim --
Posted by jhande on Wednesday, July 19, 2006 12:23 PM
Sorry to bring this thread up again but I need some guidance.
Maybe I'm blind besides nuts, but I'm having troubles finding quick disconnects. Confused [%-)]
I'm trying to go with your guys recommendation of using the regular vinyl hose. I've found QD that fit the braided hose (have to cut the hose) but not having much luck finding one that will screw onto the end of the hose. Well, except for one on eBay but I'm not an eBay type of shopper (never bought anything from there) and the item ships from Taiwan.  Shock [:O]
There must be some reputable online shop that carries such an item... I would think?
Or should I chance buying from Evil Bay? GULP!!!
Click Here to see it at eBay.
-- Jim --
    May 2005
Posted by Bgrigg on Wednesday, July 19, 2006 12:57 PM
I think if you really need the quick connects you may have to stick the the braided hoses, unless you were going to put an adater to the larger hose connection on each vinyl hose. That's starting to sound pretty clunky!
So long folks!
Posted by jhande on Wednesday, July 19, 2006 1:19 PM
I believe the female quick disconnect above should screw right onto the end of the air hose? Then all I would need is the male quick disconnect to attach to my Iwata and another for my Badger (Thayer & Chandler/Vega)? I don't think having that small of a quick disconnect between the AB & vinyl hose would be that cumbersome? At least I'm used to that with all my larger automotive air tools.
I did think about making a manifold instead. But then I'd eventually end up with a twisted octopus at the work area. Remember, my wife and kids will have access to this too for awhile.  Sad [:(]
-- Jim --
Posted by ABARNE on Wednesday, July 19, 2006 1:53 PM
From Dixie Art:
Paasche 10' $ 9.50
Badger   10' $13.95
Iwata       10' $18.95
I can't speak about Iwata, but the Badger braided hoses seem a little thicker and perhaps more heavy duty than Paasche ones.  This is not necessarily a point against the Paasche hose because its somewhat greater flexiblity may be more to your liking.  I use my 10' Badger hose for both my Badger and Paasche air brushes not particularly due to liking Badge hose better han Passche hose, but only because the Badger hose has in in-line moisture trap and I like the 10' length vs my Paasche's 6'.
    May 2005
Posted by Bgrigg on Wednesday, July 19, 2006 2:43 PM
The vinyl hose I have uses a 3/8" NPT to 1/4" brass adapter that you would need to attach to each hose. I don't know if you can buy quick connects that have the "male" threads that those brass adapters require. To me this is adding yet another area to develop leaks and potential problems. Badger doesn't seem to offer the vinyl hose with a quick connect, and I'm thinking that must be for a reason. One reason I found the braided hose heavy for my use was that I was loathe to cut it shorter, it would spill out of the booth onto the floor and I would be "lifting" four feet of hose when I was using the AB. The vinyl hose is connected to my regulator inside the booth and is only four feet long, and since it is smaller and doesn't fall out of the booth, I'm only carrying at most a couple feet worth and it's far lighter. You might consider cutting the hose shorter if that is suitable. A shorter hose is a lighter hose.
I hear what your saying about being used to it with your automotive air tools, but you probably don't use an impact driver with the same finesse as an AB!
The manifold might be an idea for a single user, but I agree, multiple users would mean multiple problems!
So long folks!
Posted by jmathewstn on Wednesday, July 19, 2006 3:41 PM
Jim.. Try this link on ebay... seller is located in U.S. If you're looking for a QD to fit between the AB end of an Iwata hose and the AB, this is what you need. I got the same thing last week at Hobby Lobby, but I think you said there wasn't a Hobby Lobby near you.
If the link doesn't work, go to eBay and search iwata quick disconnect
HTH
Jack
