Airbrushing 1:285 scale.
    March 2006
Posted by DarkMarauder on Saturday, July 15, 2006 1:14 AM
    Spent a bit of time going through here looking for answers.  But still have a few left.  Looking to replace my Aztecs for fine detail work, the tan tip hasn't been cutting it.  To give you some backround info would probably be a good start.  I'm primarily using MM enamels and Alcad laquers and my current subjects are 1:285 scale  Mecha minatures (see http://www.camospecs.com for some of my work with the same alias).  I like to rely on my miltary modeling backround, both aircraft & armor 1:72/76, but translating camo schemes down to this scale gets a bit hairy.  Therefore the need for a hairline type AB. (OK bad pun)
    So my question/concern is with spraying my prefered meduim through an AB with a 0.2-mm tip.  Second I am looking at investing in the Iwata HP-B Plus, any comments/suggestions?
    May 2003
Posted by DrewH on Saturday, July 15, 2006 12:34 PM
First off, Welcome to the forumsSign - Welcome [#welcome] Post often and share your wisdom with us.
I like your way of thinking. I would say the Iwata also as it is a laquer friendly ab. I would recomend a badger 100F (yup, I have one) if you were not going to use it with laquers. The teflon seals used by Badger and Pasche deteriorate fast if you use laq. in them. I often regret not getting an Iwata for that reason.  I'm not too familiar with the diffrent tips Iwata uses, but I think their HP-C custom is the fine/detail ab they make(ok, just correct me Iwata fans. I'll be waiting, curled up in the fetal position). I would invest in the fine ab. If you like the Aztec you have for overall work, keep it. Break out the fine ab for the detail work and weathering. That is how I use mine.  I have a bader 155 for overall work. Then I use the 100F for all the camo (freehand, cause it will) and shading or whatever for weathering.
Hope I helped a bit. (waiting on the fans tho.)
Drew
Take this plastic and model it!
    July 2004
Posted by tho9900 on Saturday, July 15, 2006 1:06 PM
Drew - ::hefting baseball bat::  we're here!!!!     Evil [}:)]  I got this image of a bunch of Iwata users strolling into the room with baseball uniforms and bats with makeup on, like in that movie "The Warriors"  Laugh [(-D]
The CM-C probably does some of the higher detail work of the Iwatas (with a bigger needle/nozzle than the HP-B Plus) but it is about $350 roughly.  The HP-B Plus with the .2mm needle probably can achieve close enough to fill your needs, at about 1/2 the price ($159.00) of the CM-C.  I don't think with what we do with modeling, the difference can be that appreciable but if you want the CM-C go for it.  I probably would go for the HP-B Plus or HP-B or C Plus Highline ($189.00)  for that size modeling if it were me.
    May 2003
Posted by DrewH on Saturday, July 15, 2006 1:15 PM
::: Curled up, sucking thumb, holding up an Iwata hoping for a light whooping::::::Black Eye [B)]Dead [xx(]Ashamed [*^_^*]
    May 2005
Posted by Bgrigg on Saturday, July 15, 2006 2:08 PM
And here I was thinking like the movie "A League of Their Own"...
Mischief [:-,]
So long folks!
    May 2003
Posted by DrewH on Saturday, July 15, 2006 2:20 PM
I'm not touching that one. Wink [;)]
    July 2004
Posted by tho9900 on Saturday, July 15, 2006 5:59 PM
Mischief [:-,]
hmmm  I look more like the brunette I think....  Wink [;)]  actually I would probably be more scared if they came in the room than the guys from The Warriors... a little more scary looking...
    March 2006
Posted by DarkMarauder on Saturday, July 15, 2006 10:48 PM
I'm soooo glad we can stay so focus'd here! Sigh [sigh] [& shakes head] Smile [:)]
Thanks for the welcome and the input thus far.  I'll try not to be stranger.
    May 2005
Posted by Bgrigg on Saturday, July 15, 2006 11:03 PM
Umm, sorry 'bout that! Don't mind us, there's a group of Iwatans on the loose and some Badger folks (like me!) that try to contain them...
Anyway, sounds like you've picked out a nice brush, and
Sign - Welcome [#welcome] to the forums! Pull up a keyboard and stay a while!
And just to clarify, you'll try not to be stranger, or not try to be a stranger? Mischief [:-,] I'm hoping the latter as you'll have your work cut out for you if it's the former!
So long folks!
    March 2006
Posted by DarkMarauder on Sunday, July 16, 2006 12:04 AM
Ah see, that's what I get for not buying a vowel.  So while I did intend to state the former, the latter may be more fun to strive for. Big Smile [:D]
    May 2003
Posted by DrewH on Sunday, July 16, 2006 12:11 AM
This happens LOTS hereLaugh [(-D]
Now, back to our scheduled sillynessTongue [:P]
Posted by jmathewstn on Sunday, July 16, 2006 8:50 AM
Speaking of clarity.. this really changes things for me! I never knew we had to actually choose!
    May 2005
Posted by Bgrigg on Sunday, July 16, 2006 11:25 AM
Jack,
Some things we choose, some things are chosen for us! Wink [;)]
So long folks!
