Silent / Quiet Compressor advise?
    February 2005
Posted by Armentage on Monday, July 17, 2006 6:46 PM
Guide to Decibels - How loud is loud?
SilentAire's own decibel chart
I own a Paasche D500 compressor and is it LOUD! I live in an apartment and hate running the thing (Imagine how my neighbors feel about it!)  My girlfriend can't stand it either, and I've begun looking into something new (and quieter). I've measured the D500 at 80+db, using a Radio Shack sound meter.  Prolonged exposure to 85+db can cause hearing damage according to the American Hearing Association, so this is no laughing matter.
I did a search and here and came up with a few opinons, but the majority of posts are all rather old (circa 2004) so I'd like to get some fresher opinions.  How loud are these compressors compared to the D500?
  • Paacsh D500- The Reference db to beat
    • 80-85 db (VERY loud)
    • Just below the hearing damage range
  • Iwata Sprint Jet
    • 65 db - Measured in a loud art supply shop; might actually be quieter
  • SilentAire Scropion I
    • 20 db (FSM Forums)
    • 55 db according to Silentaire.com
    • 20PSI max (FSM Forums)
    • 40PSI  max according to Silentaire.com
  • SilentAire Scropion II
    • 30 db (FSM forums, unlikely given how loud other compressors are)
    • 55 PSI
  • ABD TC-20T (Suggested by 3 posters!)
    • Tank Compressor that switches on occasionally.  Quiet during the filling phase
    • Reportedly 47dbs
  • CO2 Tanks
    • 20lbs of air will last around 4-5 models
    • No moisture problems
    • Must be refilled
    • Fill ups don't cost much, but there's a start-up fee involved.
EDIT -- SilentAire claims 40 PSI.
A concern I have is the max PSI.  The Scoprion I is very attractive, but is rated at only 20PSI.  I usually brush between 18 & 20, and I'm worried that a MAX of 20 won't cut it once I have my moisture trap/regulator on there.
Any other suggestions?  I'm a little uncomfortable with the CO2 tanks, and I'm hoping to spend under $200.
How do the "silent" tank compressors work?
They works on the same principle as the larger compressors. It kicks on to replenish the air supply in the small tank (quietly). Once the pressure is met it shuts off.
How loud is too loud?
Quoted from Guide to Decibels - How loud is loud?
Any sound above 85 dB can cause hearing loss, and the loss is related both to the power of the sound as well as the length of exposure. You know that you are listening to an 85-dB sound if you have to raise your voice to be heard by somebody else. Eight hours of 90-dB sound can cause damage to your ears; any exposure to 140-dB sound causes immediate damage (and causes actual pain).
EDIT -- Information I've gotten out of the posts.
EDIT -- I've measured a Paasche D500 at 85+db
EDIT -- Added DB ratings I found by searching the forums
EDIT -- Links to information about decibel ratings
EDIT -- Measured the Iwata Sprint Jet at 65db
    August 2004
Posted by Tankmaster7 on Monday, July 17, 2006 6:57 PM
I have an Iwata silent compressor. It comes with a built in moistur trap and regulatro and even so gives me a max working pressure of about 28 PSI. It's not very loud at all. I forget  which model it is though.
-Tanky Welcome to the United States of America, a subsidiary of Exxon Mobil Corporation, in partnership with Halliburton. Security for your constitutional rights provided by Blackwater International.
    February 2005
Posted by Armentage on Monday, July 17, 2006 7:38 PM
Can you be a little more specific about how loud it is?  Would you compare it to your fridge, or a hair dryer? Maybe a power drill (but less high pitched)?
    August 2005
Posted by eizzle on Monday, July 17, 2006 7:56 PM
http://www.airbrushcity.com/121tk.htm This one is awesome! Very, very quiet, and is pretty inexpensive. I have one and I really like it!
Colin
 Homer Simpson for president!!!
    June 2006
Posted by MaxPower on Monday, July 17, 2006 8:32 PM
Here's the one I plan on ordering.
click!
The TC-20T... second one down. It actually mentions being quiter than your compressor by name. Thumbs Up [tup]
    August 2004
Posted by Tankmaster7 on Monday, July 17, 2006 9:25 PM
It's definitely quieter than a hair drier. It really can't be heard more than 15-20 feet away from it. I would say it is about as loud as a comparitively quiet power drill, but as you said, less high pitched.
    February 2005
Posted by Armentage on Monday, July 17, 2006 9:55 PM
Tankmaster7 wrote the following post at 07-17-2006 6:57 PM:
BTW specifically which silent Iwata compressor are you using? The Spirit Jet?
    May 2003
Posted by kirk4010 on Monday, July 17, 2006 9:58 PM
I have the scorp. I, noise will not be an issue with this unit.   I get just a tad above 20 PSI with the built in moisture trap and a regulator I bought at a hadrdware store and attached my self.  The PSI I get is just fine for my work.
The art of war is simple enough. Find out where your enemy is. Get at him as soon as you can. Strike him as hard as you can, and keep moving.-Ulysses S. Grant
    February 2005
Posted by Armentage on Monday, July 17, 2006 9:58 PM
How exactly does that work?  Does it click on and (loudly) fill up the air tank, and then stay silent until the air is depleted?  Does it fill up the tank quietly and then only fill the chamber as needed?
I've seen a lot of tank models that claim to be quiet, but I have a feeling that they are NET quietier; that they fill up the tank and then switch off until more air is needed.  Is this true?
Posted by jhande on Tuesday, July 18, 2006 8:04 AM
 eizzle wrote:
#121TK This one is awesome! Very, very quiet, and is pretty inexpensive. I have one and I really like it!
The ABD TC-20T... second one down. It actually mentions being quiter than your compressor by name. Thumbs Up [tup]
The 2 above are basically the same compressor. I had mine (ABD TC-20T, because I ordered as an Iwata AB kit) since Christmas. It is very quiet when it fires up. Think of it as one of those fish tank power filters. It's a bit noiser than a refrigerator (at leat mine) and quiter than a sewing maching, actually almost anything else that has an "on" switch in my house besides light bulbs, LOL. I get migraine headaches easily, but I can fall asleep just fine with that compressor running in the same room.
It also has plenty of power (cfm and max PSI) to handle most task compared to other compressors costing much more. My wife uses it for the occasional T-shirt spraying (50 - 60 PSI).
I've searched and tested compressors for months before I decided on this one. It is the quietest I could find and I really like the extra power.
Highly recommended by this hobbiest.  Wink [;)]
Gee... I should start getting a commission...  Tongue [:P]
-- Oop's... Edit --
To answer the other part of your question...
It works on the same principle as the larger compressors. It kicks on to replenish the air supply in the small tank (quietly). Once the pressure is met it shuts off (silent LOL).
-- Jim --
"Put the pedal down & shake the ground!"
    May 2005
Posted by Bgrigg on Tuesday, July 18, 2006 9:02 AM
Of course I am now left with an image of you face down on your build table, hissing Iwata in hand, while your snoring drowns out the compressor's relatively quiet "pock, pock" sound. Clown [:o)]
So long folks!
    February 2005
Posted by Armentage on Tuesday, July 18, 2006 1:28 PM
Does anyone have any waranty/reliability information about the the TC-20T, SilentAire, or the Spirit Jet?
My D500 actually broke down after only a year of use.  I sent it back to Paasche (big pain shipping a 12lbs chunk of blue iron) and they return it to me in tip-top shape after 10 days (free return sipping.)
Who makes the TC-20T?  Who repairs it?
    February 2005
Posted by Armentage on Tuesday, July 18, 2006 6:42 PM
Another interesting find -- SilentAire claims that the Scorpion I actually runs around 40PSI, and the II at 55PSI, and rate their loudness closer to 50 db.
    February 2005
Posted by Armentage on Wednesday, July 19, 2006 9:23 PM
So I went out and bought a Radio Shack sound meter today!  I measured my D500 with it.... EIGHTY DECIBELS!   80+ db is very loud.  It's just shy of the range that causes hearing damage with prolonged exposure.
I had a lot of fun on the way home with this meter.  An NYC subway runs at 90+db while you are inside riding, and puts out about 85 db while passengers are getting on and off at a station.  Walking down Midtown NYC at 4pm, there's about 75db of ambient noise.  My aircondition puts out about 60, and my microwave puts out around 55.  The scale is logarithmic, so a 75 is MUCH louder than a 55.
Posted by gjek on Wednesday, July 19, 2006 11:18 PM
I use a 20 lbs CO2 cylinder with regulator. It is completely silent. The only noise is the air exiting from the airbrush. There is no moisture in the CO2 to need to trap . There is no need of power to run it. It is completely portable. There are no parts to wear out. The 20 lbs size is very common and easy to get. I can easily do 4 or 5 models before refill @ $12.00. That is about $3.00 or less per model. That's a lot of models before I incure the cost of a good, silent compressor.   Just my opinion   Greg
Msgt USMC Ret M48, M60A1, M1A1
    May 2005
Posted by Bgrigg on Thursday, July 20, 2006 12:03 AM
While I agree that a CO2 tank is probably the quietest, I can't help but notice that you didn't include the cost of the tank and regulators in your cost analysis... Smile [:)]
I'm lucky in that I don't have to worry about noise and hooked up a garage compressor with tank that only cost me about $75. When it breaks down (I am under no illusion about it's longevity!) I will replace it with a more expensive and much larger tank garage compressor. If I was worried about noise, I would certainly look into the CO2 system.
So long folks!
Posted by jhande on Thursday, July 20, 2006 1:32 AM
That's one reason why I don't use CA glues and just Testors Model Cement. It wasn't a pretty sight when I woke up only to find my face glued to my build.  Shock [:O]
-- Jim --
Posted by jhande on Thursday, July 20, 2006 2:27 AM
    • Anyone have DB ratings for this model?
Does anyone have any waranty/reliability information about the the TC-20T, ...?
During my pre-purchase research (summer & fall of '05), I contacted quite a few people & places regarding compressors, especially the TC-20T & 121TK / 121ACN.
I had received an email regarding the decibal levels. I can't find the email or remember the exact numbers, but 37 to 47 rings a bell. I think it might have been 47db?? Even at 47 that is a very exceptable noise level. It's a bit noiser than my A/C unit, but I can talk on the phone, watch TV, listen to my wife ramble... uhm talk, listen to the stereo while it is running without distraction.
I was also told that it was believed to be a product of Sparmax [look at their TC-501(asr)] as they will custom build their products for their clients.
AirBrush-Depot gives a 1 year warranty. Info is included at their site with the compressor - Click HERE to see the TC20 Manual in Acrobat.
I have to agree that CO2 would be the quietest way to go. But I'd rather have my compressor. Unless it dies on me, I don't have to worry about running out of air and making a trip to finish a build. Plus it's a one-time investment, no cost of constant refills.
-- Jim --
    February 2005
Posted by Armentage on Thursday, July 20, 2006 8:25 AM
47dbs is VERY VERY quiet.  A conversation between two people runs between 65 & 75 dbs.  If this is true, then the TC-20 is a real winner!
I actually wrote to ABD last night and asked them to purchase a sound level meter and measure their various compressor models.  The meter costs only $50 from Radio Shack and if their compressors really are that quiet, it would be a huge marketting win for them.  Lets see what happens!
And thanks for all the replies everyone - I'm hoping to grow this thread into something that can be stickied.
Posted by jhande on Thursday, July 20, 2006 10:24 AM
I know I can hear my wife and kids talking too easily over the sound of the compressor. Sad [:(]
Good luck in getting them to purchase the sound meter and advertise the decibal levels. After all, those compressors are already their biggest sellers.
You are welcome, hopefully it helps in your decision making.
-- Jim --
    August 2005
Posted by eizzle on Thursday, July 20, 2006 11:37 AM
Another good way to keep everything quite is to place the compressor on a soft pad, I used pipe insulation. It has rubber feet on it already, but sitting on my book case, it transmists a lot of vibes, so that is one thing to look into when you purchase one, where are you going to put it and will the vibration make it louder.
Colin
Posted by jhande on Thursday, July 20, 2006 3:37 PM
Good point Colin Wink [;)]
I put mine on a piece of scrap carpeting even though it's already on a thinly carpeted floor. Made a noticeable difference.
-- Jim --
Posted by Anonymous on Thursday, July 20, 2006 5:06 PM
I bought a TC-20T from airbrush depot recently and 47db sounds reasonable. It´s very quiet and I was pleasently surprised when I first turned it on. Having a normal conversation while it´s turned on is no problem and because it has a tank it´s not running all the time. It also has rubber feet so that vibrations are reduced. For the price I think it´s a very good option.
    February 2005
Posted by Armentage on Thursday, July 20, 2006 5:12 PM
Think you want to try measuring the sound with a sound level meter? :)
Radio Shack  Sound Level Meter
Posted by Anonymous on Thursday, July 20, 2006 8:24 PM
I´d love to do that, but I live in Norway so that meter quickly gets expensive. Buying something similar here costs almost $150.
Posted by gjek on Thursday, July 20, 2006 10:56 PM
Actually it is easy to keep up with how much CO2 you have. When you get a 20lbs cylinder, you buy 20lbs of CO2 above the weight of the cylinder. Just weigh the cylinder before starting a project. If the total weight weight of the cylinder has dropped 17 or 18 lbs, go get it filled. You don't have to wait till you run out half way through a paint job.   Greg
    February 2005
Posted by Armentage on Friday, July 21, 2006 1:03 PM
I'm getting a little obsessed with this :)
I went down to one of the art supply shops in town with my Sound Level Meter, and actually convinced them to let me measure an Iwata Sprint Jet.  Let me start by saying the Sprint Jet is a very cool looking compressor.  It's half the size of my Paasche, and weighs nothing.  It has a very nice carrying handle, as well as rubber feet.
The Sprint Jet was pretty darn quiet.  I measured about 65dbs coming off of it, similar to a room AC or standing floor fan.   I would have bought it right there, but this art supply shop charged about $200 too much for it (much to my chagrin).
    February 2005
Posted by Armentage on Saturday, October 7, 2006 10:57 AM
Okay -- I haven't updated this thread in a while, but I have some results!
I finally purchased a Iwata Sprint Jet from Dixie Art.  Great price and good service.  The compressor is far more "deluxe" than a Paasche D500.  Smaller, Lighter, more preasure when I need it.  Integrated moisture trap andd regulator, all for $160 new.  Worth EVERY penny. The on/off switch and the carry handle are a HUGE win over the Paasche D500.
The SprintJet runs in the low 70db, (compare to the D500s 85).  The sound it makes is of a much higher pitch; instead of the horrible rumble of the Paasche, it's more of a gentle wheezing.  For me, it's a much more tolerable sound.  it does NOT scare my girlfriend out of the house like the Paasche. SprintJet doesn't vibrate very much either; my Paasche would do a dance across my hard wood floor if I didn't put something under it.
All in all, the Sprint Jet is a much more pleasant Compressor to work with.  I recommend it!
    October 2006
Posted by Inquisitor on Saturday, October 7, 2006 9:00 PM
Mine has a hum that is quieter than my computer while it's running.  Since it has a 1/2 gal tank, it doesn't run constantly, even with heavy spraying.
Totally worth the investment if you are a serious modeller.
    September 2005
Posted by TB6088 on Sunday, October 8, 2006 12:07 PM
Greg,
Hey, another one of US!  I was beginning to wonder if anyone else had stumbled upon the only truly "silent" (and dry) air source--- a CO2 tank.  It also handles presssures far higher than most of the compressors that are being discussed.  I get way more modeling between refills than you, but even at the rate you use it, it's a bargain, especially since it uses no electricity.  Thanks for letting me know I'm not alone.
TomB
