Question about painting fine lines
    November 2003
Posted by TryintoModel on Thursday, August 3, 2006 1:11 PM
I have an T&C Omni 4000 and a Badger 150.  I had the Badger prior to the Omni.  I really like the Omni because it seems to paint easier with the gravity feed and it seems much easier to clean.  However, I have had a really hard time painting fine detail with the Omni.  To me, I still get too much overspray.  Should I be able to paint fine detail with an Omni?  Would my Badger, using the fine tip, be the better way to go?  I'm at work just thinking about it, I know I'll have to give it a try to find out if the Badger works better.  But I was wondering if I should be able to paint fine lines witht he Omni without overspray.  When I try with the Omni, if the air pressure is too high, it blows the paint to much and causes runs.  If I try to lower the air pressure enough to get rid of the runs, it spits too much overspray.  How close do you get to your model when trying to paint a fine line?  I'm just wondering if a fine tip and needle is supposed to solve this.  I don't think that the Omni has a fine tip and needle option.  I think it just comes with one size.
Sorry for the rambling.  Any help would be appreciated.
    January 2003
Posted by Triarius on Thursday, August 3, 2006 2:34 PM
You should be able to get finer than 1 mm with the Omni 4000. I just started using mine, and had little trouble getting that fine. This airbrush has a dual taper needle, allowing for both coarse and fairly fine work with the same brush.
First thing: take off the air cap guard, reverse it, and put it back on. This allows you to get closer and changes the air flow pattern at the tip.
What follows works for me:
Make sure your paint is adequately reduced (thinned). For fine lines, thinner is better.
Reduce your air pressure to 8 to 10 psi.
Practice, practice, practice!
A final tip: I've discovered that you can adjust the trigger resistance to suit your fingers by adjusting the spring adjuster—helps a lot with control.
    November 2003
Posted by TryintoModel on Thursday, August 3, 2006 4:06 PM
Thinning might be a big part of the problem.  I tried thinning a bit more than normal, but maybe it needs to be more.
What is the air cap guard?  I'm trying to picture it, but I'm coming up blank trying to think of any of the pieces that could be reversed.
    January 2003
Posted by Triarius on Thursday, August 3, 2006 4:55 PM
The air cap guard is part no. T8131G. This is just the cone. When the air brush is fully assembled, it resembles a rocket nozzle on the front of the airbrush. It has a knurled rim. Unscrew, reverse, screw on finger tight only. On the second page of the instructions, this procedure is listed under the heading "FINE DETAIL."
    November 2003
Posted by TryintoModel on Thursday, August 3, 2006 5:31 PM
Ahhh, I see.  I got home and checked it out.  I guess it would help if I read instructions, but what fun would that be? Smile [:)]  I'll have to practice some more and see what results I can get.  Thanks for the help.
    January 2003
Posted by Triarius on Friday, August 4, 2006 9:07 AM
I always RTFM—some of the things I've played with, it helps them not to go "BOOM!" unexpectedly… Dead [xx(] It also keeps me from breaking things that really don't need to be broken, as I also occasionally Ashamed [*^_^*] subscribe to the philosophy "If it doesn't fit, force it. If it still doesn't fit, get a bigger hammer. If it breaks, it needed fixing, anyway!"Censored [censored]
I think I know why modelers, in particular, tend not to read instructions: so often, the ones that come with the kit are wrong, misleading, or inadequate. And then there are the translation problems: "Farb now the glimrod," and "Craunch along the stantion at the mashing together place." (Quoted from the comic strip "Shoe" by Jeff McNelly. IIRC, he was quoting from a set of instructions.) Mischief [:-,]
    March 2006
Posted by Dubau on Friday, August 4, 2006 9:28 AM
LOL,
I have an Omni 4000 and I LOVE it. You should be able to do the fine lines with np at all with this, just do what Triarius says and you should do fine, lol no pun there
Have a GREAT day
Bud
" You've experienced a set back, and without set backs and learning how to fix them you'll never make the leap from kit builder to modeler "
Posted by MikeV on Sunday, August 6, 2006 10:02 PM
Reversing the tip guard doesn't affect the air flow at all, it just allows you better access to the needle to clean it with your fingernails as T-shirt artists do. It also allows you to get even closer as mentioned.
    January 2003
Posted by plasticmod992 on Sunday, August 6, 2006 10:40 PM
I've had an opotunity to use the Omni brush and I did a "head-to-head" with my Iwata HP-CR years ago.  The Omni performed great, especially at spraying fine lines.  I'd agree with others here that, while reversing the tip-guard doesn't affect the airflow, it did allow me to get in close as needed to maintain the tight line pattern.  Also metioned, that I would ehco is, (and it's an important one) is, paint-to thinner ratio combined with an effective air pressure setting.  My set up consists of thinned paint mixed 1:1, with the compressor set to, between 10 to 15 psi for fine lines with T/MM enamel and Tamiya acrylics.  My Iwata, and similarly (if not identical) the Omni sprays very tight fine lines with their reletively large tip/ needle size of approx. .5mm.  We've talking camo outlining on 1/72nd scale in my case!  I've also had similar/ identical experience with the Badger 150 as well, I just like a gravity feed airbrush for ease of use.  So I think you're got all the right ingredients for shooting some nice lines for camo and or detail if you make some minor adgustments in set up.  Hope this helps!
Take a gander at this 1/72nd scale MiG-23 Flogger I did with an Omini airbrush years ago, all free-hand:
Greg Williams Owner/ Manager Modern Hobbies LLC Indianapolis, IN. IPMS #44084
    January 2003
Posted by Triarius on Monday, August 7, 2006 9:30 AM
Mike, while I would normally defer completely to your vast knowledge and experience Make a Toast [#toast] of airbrushes, I must partially disagree, largely because I did not speak as precisely as my wont.
The air cap guard has nothing to do with internal air flow. What I should have said is that reversing the tip affects the external pattern of airflow—the way the stream of air from the airbrush itself interacts with the standing air in its path. There was an article in the March, 2001 FSM "Airbrush Aerodynamics" that briefly discussed this (page 48, sidebar). At longer distances, the air cap guard actually serves as a secondary nozzle, reducing turbulence at the oriface. At close distances, this is not necessary—the air cap guard may even produce more turbulence.
Do you really clean your tip with your fingernails? Shock [:O]
