WOW all 3 won't spray!
Ok, we have to look at common variables...
Is there air getting to the AB's?
Were all 3 AB's put back together correctly after cleaning?
Are you sure the AB's will/were spraying air before adding the paint?
Was the paint thinned enough?
Is 16 psi enough to blow the paint out?
Did the solvent in the paint eat any seals in the AB's?
Disconnect the AB from the airhose and blast some air.
Dismantle and clean an AB, looking for any problems.
Try again.
Good Luck!
