some questions about my new airbrush
Posted by Anonymous on Thursday, August 21, 2003 9:36 AM
I just bought a new vega 200 badger and i have some questions about it.
1 Is it bad to take it aprat to clean it after everry paint job
2 What is a easy way to clean the bottel cause u cant remove the tube i run thinner through it about two time + when i spray thinner throught it.
3 Should my color cup have a lid and is it bad that it dosent.
    May 2003
Posted by styrene on Thursday, August 21, 2003 10:44 AM
1. No. That process should keep it funtioning efficiently for a long time to come. I'm still using a Paasche H that I bought in 1975, and it stil works great.
2. Buy a pack of pipe cleaners, cut 'em in half, put a few drops of thinner on one end, and run it through the tubing. The best thing you can do is to go to your color cup exclusively. When I first started airbrushing, I used the bottle all the time, but after doing a few kits, I found that I could paint an entire 1/35 tank with my color cup about 2/3 full. I also found I wasn't wasting as much paint doing it this way, either.
3. Not necessarily. Neither of my Paasches (H and VL) have covers for theirs. It's not bad that way...it's the way they were designed. The only thing to be careful of is making sure you hold your brush steady when you use a cup so you don't go dumping paint when you accidentally tilt the brush the wrong way (It took me a couple of times to learn that lesson.)
Hope this helps you.
Gip Winecoff
Posted by Anonymous on Thursday, August 21, 2003 10:50 AM
Hey thanks a lot Styrene.
Posted by MikeV on Thursday, August 21, 2003 7:03 PM
I echo Styrene's statements. One thing to watch though is that sometimes a pipe cleaner will leave a little material inside the airbrush which can cause clogging problems, but that doesn't happen very often. I prefer to use the Airbrusher's Brushes that Dixie Art and other places sell. This set of brushes will clean anything you want on the airbrush.
Posted by Anonymous on Thursday, August 21, 2003 10:05 PM
Cool ill look for them on the net.
