Bubbles in my cup
Bubbles in my cup
Posted by gjek on Thursday, August 10, 2006 9:38 PM
I am using an Iwata Revolution and sometimes get bubbles in my paint cup and sometimes when I am cleaning it bubbles appear at the nozzle cap joint. The nozzle is on as tight as I can get it with my fingers. Can I use something as a gasket or sealer? Is this the real issue or have I missed the boat?
Msgt USMC Ret M48, M60A1, M1A1
    May 2003
Posted by DrewH on Thursday, August 10, 2006 10:38 PM
No, you likely have a leak in the nozzle cap and tip, or possibly a deformed tip. Do you have a can of  Iwata lube? If not you may want to get one. It helps keep everything sealed up. You can also use wax as gaskets. Put some on the threads and base of the tip before assembly. And again on the needle from the taper back. Don't use too much pressure tightening or it can collapse the tip and deform it. You may need a new one. Check the tip under a magnifier and see if it is deformed. Hope it helps a bit.
Drew
Take this plastic and model it!
jwb
    February 2006
Posted by jwb on Saturday, August 12, 2006 1:36 PM
Good info DrewH. I'm having similar issues with a Paasche VL.
Jon Bius
AgapeModels.com- Modeling with a Higher purpose
"For I know the plans I have for you," declares the Lord, "plans to prosper you and not to harm you, plans to give you hope and a future." ~ Jeremiah 29:11
