I was working on free-handing my Me-262 camo, doing a mottled finish. I used my Paasche VL, #3 tip with Polly S paints. I used the adjustment wheel to push the trigger back just a bit, so I could just lightly push down on the trigger to get the "spots". It worked great for a little while, then suddenly it just stopped flowing.
I looked at the tip. "Ah<" I thought, "so that's tip dry..."
What a pain.
To top it off, my Paasche is behaving poorly. I clean and clean, yet I still get bubbles in the cup, and even bubbles around the trigger.
Any ideas for combatting tip dry would be great, as well as any advice from Paasche users.
My little Aztek 370 has almost no problem with tip dry, but it's not near as precise on the trigger control, and doesn't have the adjustment wheel.
The one section I managed to complete don't look bad- so hopefully I can get it knocked out without too much more problems.
Jon Bius
AgapeModels.com- Modeling with a Higher purpose
"For I know the plans I have for you," declares the Lord, "plans to prosper you and not to harm you, plans to give you hope and a future." ~ Jeremiah 29:11
