If you look in my sig at my current work bench I am working on three models right now.
The P-40 Tiger Shark I started at the beginning of July. It is my first attempt at doing a model with airbrush and everything. I think I have done a decent job. I am still learning my airbrush but am feeling more and more comfortable with it. I am very happy using the Tamiya acrylics. I just need to get my mixing paint and thinner down.
Anyway, I have a few questions:
Project 1: The P-40. I have painted it and airbrushed it with a coat of Future. I am waiting to get some decal setting solution before I put on the decals. Once that is done I need to spray on a coat of flat for the final finish. My question is what is the best flat to use? I can't find a bottle of Tamiya to airbrush, I only find the spray cans.
Project 2: The F-19. This project I started a long time ago. I had her almost complete, except the gray and decals. When I pulled her out of the box she's been in I had to re-glue some parts. Respray the white since it yellowed very bad. I also airbrushed the two toned gray. This came out great. Again, I am waiting to get the decal setting solution. My question here is: I have read that many of the newer aircraft are not coated with a flat, but with a gloss/semi-gloss to aid in airflow. What would be the best final finish for this model?
Project 3: The A-37. I started this project in late 2002 after I had all my paints, the airbrush etc. I was scared to try the airbrush and just made excuses for not completing this model. Anyway. I am working on it again. I am at that point where I need to airbrush the main paint job. With the P-40, I did not use a base primer. I just painted the main paint scheme directly on the plastic. I am thinking I want to try a primer. When should you use a primer, or should you use it all the time? What is the best primer? I can't find any bottles to airbrush, just the spray cans again in Tamiya.
Thanks in advance. I figure that if I start posting here it will keep me more involved with my models and make me want to complete them instead of storing them in my closet. I have a full list of the models in my closest in my "
introduction thread".
g
