Your Thoughts Please
    August 2006
Posted by tmak2654952 on Sunday, August 20, 2006 9:02 AM
I have my first airbrush purchase narrowed down to either the Omni 4000 or the Badger 155.
I will be using it to paint and weather HO model railroad box cars and structures.  For the most part I believe that I'll be using acrylic paints.  What are your thoughts on the above two airbrushes for my usage?
Tom Makofski NorthEastern Wisconsin Free-Mo Total Membership of 2 and Growing! tmak@new.rr.com http://www.pbase.com/tmak2654952/galleries
    May 2005
Posted by Bgrigg on Sunday, August 20, 2006 9:20 AM
Either would be excellent. I've heard only good things about both brushes, with maybe "more" good things about the Omni 4000.
So long folks!
    March 2006
Posted by Dubau on Sunday, August 20, 2006 9:59 AM
I have an Omni 4000 and WOW I LOVE it. if you do low PSI and flip the tip on the A/B around you should get a fine line, And as for the other A/B sorry to say I do not know anything on that one
Good Luck
Bud
" You've experienced a set back, and without set backs and learning how to fix them you'll never make the leap from kit builder to modeler "
Posted by Anonymous on Sunday, August 20, 2006 10:09 AM
weathering boxcars? Big Smile [:D] Cool! What railroad do you model? I do the Western Pacific from the late 60's/early 70's myself.
as for the airbrushes, same as above, I've heard both are quite good.
    August 2006
Posted by tmak2654952 on Sunday, August 20, 2006 10:14 AM
Ideally WC, 1900-1940.  Obviously there will be some SOO, CNW and MILW.
    January 2003
Posted by Triarius on Sunday, August 20, 2006 10:40 AM
I just got an Omni 4000 a little while ago, haven't used it too much, but I already absolutely love it. I was a modelrail—wish I had the time, now. Some day… anyway, I think the Omni will serve you very well in HO or even N scale. I can't believe how small I can get the lines! And it's a positive joy to clean.
There was a lot of discussion on this not too long ago. Search the forums on "airbrush".
Posted by MikeV on Sunday, August 20, 2006 1:08 PM
One is siphon-feed and the other is gravity-feed so it is an apples to oranges comparison in my opinion overall. I would personally go with the Omni 4000 as you probably don't need the volume of paint that a siphon-feed can hold in a jar.
The Omni will also spray better at lower pressures and is a little easier to clean, although not much.
Hope this helps.
