I'm a CO2 fan for all the advantages CO2 offers.
1.quiet. 2. no water spitting. 3.no power needed. 4. very portable
Yes a new regulator is expensive however you don't need a new one. Get a used one. CO2 stays at about 800 psi in the tank so the regulator must be rated higher than that. I went to an auction and picked one up with a nitrogen tank for $25. It was from a welding rig and the regulator was raited over 3000psi due to the nitrogens higher pressure. I then traded in the nitrogen tank at the gas company for a 20lb CO2 tank. You want to use CO2 over nitrogen because it is cheaper. I exchange an empty tank for a full one when I refill instead of waiting on them to refill the same tank.
Msgt USMC Ret M48, M60A1, M1A1
