[censored] AB
[censored] AB
Posted by Anonymous on Friday, September 8, 2006 4:12 AM
Ok, I love my AB, it gives me a great finish, I haven't had any major problems (until now!), its dual action and it was cheap. BUT, I have had this little problem before. When (after unassembly and a full clean - I usually just spray until no more colour comes out, then spray turps throuth it again till no more colour comes out, then backflush and clean the nozzle and neddle tip by dipping it in turps - this process was recomended by someone much more experienced than me and has never given me problems) I go to put the AB back together, I put the trigger back in, and then place the 'spacer' ( a small metal piece that has a tab on the top, is curved in the middle, and a square hole in the middle, that sits behind the trigger tab up and outward bit of the curve toward the back of the AB) in behind it. The problem is the spacer is loose, moving back and forth (and a bit up and down)  freely and when the trigger is pulled it does not move the needle whatsoever. Last time this happened me and my dad figured it out, but this time no luck (yet). The provided manual says very little on re-assembly, I NEED HELP PLEASE!!!!!!!!!!!!!
Thanks in advance
Will
Posted by mass tactical on Friday, September 8, 2006 12:39 PM
It would be very helpful to know what type of airbrush you are using. They all have their own nuances.
    January 2004
Posted by MusicCity on Friday, September 8, 2006 3:10 PM
It sounds like the piece behind the trigger on the Badger 100 and 150 brushes.  If so that piece itself cannot be loose since it is under spring pressure from the spring behind it.  If it is loose in the body it's most likely because the spring is not seated properly.
The spring housing has several parts as can be seen in This Diagram  The most common cause I've run across with the spring sticking is that the inner section (part 51-011) has a flat side that gets stuck so that the piece doesn't slide properly.  Check that assembly and I think you'll find something bound up back there.
    May 2005
Posted by Bgrigg on Friday, September 8, 2006 3:20 PM
It would certainly help to know the make and model! Wink [;)]
Check to see if the needle is pushed all the way forward and that the chuck screw is tightened.
So long folks!
Posted by Anonymous on Friday, September 8, 2006 5:58 PM
OK, this is where I think I'm going to have problems. Its a 'Fine Air Brush AB-119', I got it off Evil Bay (Aus).
Will
    July 2004
Posted by tho9900 on Friday, September 8, 2006 6:57 PM
if you could post a pic of it, we might be able to tell if it is a copy of this or that airbrush brand....
I ditto the comment on the spring being stuck... you might want to take the needle barrel out (unscrew it from the back of the airbrush) and make sure no gummyness is in there and test the travel of the piston and spring out of the body.  If it doesn't pop back when you release it, you definitely have a spring problem....
    August 2005
Posted by Phil_H on Friday, September 8, 2006 7:17 PM
Will,
From your description it sounds like there is no spring tension in either the trigger or the curved lever which sits behind the trigger. (ie. the trigger is flopping backwards and forwards).
If this is the case, it may be that the entire needle actuating assembly is not screwed in far enough.  (This was a problem I have seen "out of the box" with one of these Badger 150 clones)
With the handle off, you from the extreme end (going forward towards the tip of the airbrush), you should see the following parts in the following order,
1: the rear-end of the needle
2: the needle lock nut (knurled brass)
3: the collar into which the needle lock nut is screwed (smooth brass)
4: the spring retaining screw (knurled brass)
5: The inner "barrel" which holds all these parts (in the diagram linked above, this is labelled as part number 50-030 "Tube shank", the outer end of which is knurled brass)
If part number "5" listed above isn't screwed in far enough, then the needle assembly simply will not move, the trigger and the curved "spring" lever will flop backwards and forwards. Screw it in (clockwise) and see if it engages the trigger mechanism. (You will have to eyeball this as there is no "stop" to let you know you've screwed it in far enough too far and it will lock the mechanism up solid, not far enough and it won't engage)
(BTW: I hope you didn't pay too much for it, from what I can see it looks identical to my $30 Super Cheap Autos airbrush) with a silver handle instead of black.
Posted by Anonymous on Friday, September 8, 2006 10:25 PM
OK, tahnks Phil, and pics in a minute
Will
Posted by Anonymous on Friday, September 8, 2006 10:48 PM
Sorry can't do it now, got the pics, but gota go.
Will
    August 2005
Posted by Phil_H on Saturday, September 9, 2006 7:48 PM
Will,
I believe this diagram more accurately represents the airbrush you have.
http://www.airbrushcity.com/1102n_diagram.jpg
Posted by Anonymous on Sunday, September 10, 2006 1:01 AM
Thats pretty much it Phil except it doesn't have the 'Adjustment Screw'. Here are the pics, with the unassembeled one, from right to left (at the top of the cutting board) the parts are back cover, spacer, trigger, front needle (I don't know whats its called!) cover thing, front cover. The other Sign - Off Topic!! [#offtopic] pics are off the workbench, W-I-P M41 (Tamiya), and the relativley small stash which had a Trumpy 1/35 British AS-90 added to it today after a trip to Hobbyco.
Will
Posted by Anonymous on Sunday, September 10, 2006 3:10 AM
YAY!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! Approve [^]
I GOT IT!!!!!!!!!!!!!
Thanks for all your help guys but I got it myself. I played around with how far the needle itself and the whole needle assembly was in the airbrush, it must have being either too far in or something. I don't know wether it was the needle itself or the needle asembly
THANKS!!!!!
Will
    March 2006
Posted by Shellback on Friday, September 15, 2006 8:30 PM
Make some notes in case it happens again . If your like me you wont be able to find the notes wen you need them .Big Smile [:D]
Shell
Posted by Anonymous on Saturday, September 16, 2006 5:31 AM
I would like to, but I'm afraid it would just be a waste of time. I probablywouldn't even remember I wrote notes LOL Smile [:)]
Will
