Hand painting White
Hand painting White
Posted by Anonymous on Wednesday, August 27, 2003 8:52 AM
I am currently building a 1/48th scale F-117. Have airbrushed the entire model. The problem I am having is on the tires and landing gear having white paint stick to the base coat when using hand brushes. The paint that I am using is Testors flat white enamel out of the bottle. The paint acting like it has no pigment in it. When I had airbrushed the landing gear and bomb bays didn't have this problem.
Any suggestions would be helpful.
Jeff Schlotfeld
Posted by MikeV on Wednesday, August 27, 2003 10:17 AM
You can't really paint flat Testors white with a brush, if you need to brush paint parts then you need a paint more designed with brush painting in mind such as Polly S.
Why not airbrush the wheels and landing gear also?
Posted by djmodels1999 on Wednesday, August 27, 2003 11:30 AM
Or use a spray can of white primer... That's what I do.
Posted by Anonymous on Wednesday, August 27, 2003 11:38 AM
I always spray white whenever possible. Brushed white never really works out correctly, especially if going over another color.
demono69
Posted by Anonymous on Wednesday, August 27, 2003 12:09 PM
What everyone is saying is that white paint just doesn't work with a brush. Who knows why, but it just doesnt. There are some brands that work better than others, but I've never really come across one that I think does a 'good' job with a brush.
As others have mentioned, highly recommend spraying white. It works much better (as you already saw on your landing gear.)
Good luck.
Murray
Posted by Anonymous on Wednesday, August 27, 2003 1:37 PM
Thanks for the info
Posted by Bones-coa on Thursday, August 28, 2003 9:29 AM
And just so you know, schlotfj, yellow usually does the same thing.
Dana F On the bench: Tamiya DO335B-2 with LOTS of Aires stuff (On Hold) Trumpeter A-10 with LOTS and LOTS of aftermarket goodies! (On Hold) Tamiya 240ZG (In work)
