All it really does is that it allows you to "pre-set" a needle position so that you can use the airbrush as you would a single-action unit. Simply pre-set the screw to a particular position and press the trigger.
Note that it does not prevent you from drawing back on the trigger and increasing the paint flow if you so desire.
Edit: Oops - mis-read your post... You already know what it does.
