Acrylic Thinner
    September 2006
Acrylic Thinner
Posted by shall on Wednesday, September 27, 2006 9:03 PM
I think I read somewhere (and now I can't find it again) that denatured alcohol makes a good thinner for acrylic paint.  I think it would dry faster than thinning with water.  Will alcohol work just as well for washes as for air brushes?
shall
Posted by Anonymous on Wednesday, September 27, 2006 11:56 PM
For base coats I use tamiya paint and Tamiya thinner.  For washes I use enamels.
    January 2003
Posted by Triarius on Thursday, September 28, 2006 7:44 PM
The thinner of choice varies with the brand of paint—one thinner will not work well for all. For example:
Tamiya: 90% or greater isopropyl alcohol seems best. Some have used ethyl or denatured alcohol and reported good results. However, both of these evaporate very rapidly, and under some conditions will not allow the paint to level.
PollyScale: distilled or deionized water.
I think if you search the forums on the brand name, you will find the information you seek.
Posted by espins1 on Friday, September 29, 2006 12:31 PM
I used to use isopropyl alcohol for mixing with Tamiya Paints, but depending on what you're doing it tended to dry very, very quickly.  So now I use Tamiya Thinner and it seems to work better.  One of those big bottles will last you forever.
Scott Espin - IPMS Reno High Rollers  Geeked My Reviews
    March 2006
Posted by Yann Solo on Friday, September 29, 2006 12:40 PM
 espins1 wrote:
......  One of those big bottles will last you forever.
  Wait a minute ..... mine is half full.......does that mean I'm middle age?
No matter where you go ....... there you are.
Posted by espins1 on Friday, September 29, 2006 1:22 PM
Aye laddy.  Wink [;)]
    January 2003
Posted by Triarius on Friday, September 29, 2006 2:20 PM
You can solve the fast drying problem with a drop or two of acrylic retarder—at that rate of use, one four ounce bottle of retarder will last a lifetime.
    January 2003
Posted by plasticmod992 on Saturday, September 30, 2006 12:34 AM
I was the one who reported the success and use of Denatured alcohol with Tamiya acrylics.  It was specific to just the Tamiya paints, not to be generalized for use with all acrylics.  I have not tried it with other brands, so consult with others here for alternatives with other brands such as MM/ Acryl, Polly Scale, Xtracrylix, Gunze, etc.  Denatured alcohol works outstanding for Tamiya as my primary airbrush thinner for that paint.  When I want to brush paint, I add a drop of *Liquitex Slow-Dry medium to extend its open time.  This works equally well for the dry brush technique with Tamiya as well.  Give it a shot!  Denatured alcohol solvent is sold at your local hardware and paint supply stores.  It sells for only $4.00 per quart (in my area), prices don't vary much, unless you live in CA.
Greg Williams Owner/ Manager Modern Hobbies LLC Indianapolis, IN. IPMS #44084
