Satin and Semi-Gloss
Posted by Bones-coa on Friday, August 29, 2003 7:05 AM
I've always thought that these two finishes were the same but with different names. I've since heard that they are actually different...at least I think that's what I heard. Has my assumption all these years been wrong?
Dana
Dana F On the bench: Tamiya DO335B-2 with LOTS of Aires stuff (On Hold) Trumpeter A-10 with LOTS and LOTS of aftermarket goodies! (On Hold) Tamiya 240ZG (In work)
    January 2003
Posted by gbritnell on Friday, August 29, 2003 5:25 PM
There are three types of paint finishes: glossy, semi-gloss (satin) and flat. We all know what glossy and flat are, so just think of semi-gloss as halfway in between. If you paint something satin black you will definitely see that it doesn't shine but then it does reflect some light. I hope this helps.
gbritnell
Posted by Anonymous on Friday, August 29, 2003 8:25 PM
How about just say they are the same.
Posted by Anonymous on Saturday, August 30, 2003 8:26 PM
actually, there are a lot more finishes...gloss, semi-gloss, satin, eggshell, velvet, and flat...and when self-mixing for your airbrush, you can accidentally turn some into the others depending on your thinner ratio and spray technique...it's a pain in the a_ _...especially if you're trying really hard to end up wiht super flat and keep gettin freakin satin (like me).
Posted by Butz on Saturday, August 30, 2003 8:48 PM
Hey Mer,
I think that the gloss and flats are out to get ya my dearTongue [:P]Tongue [:P]Wink [;)]Big Smile [:D].
Just have to keep your eyes open at all times....LOL
Flaps up, Mike
  If you would listen to everybody about the inaccuracies, most of the kits on your shelf would not have been built Too Close For Guns, Switching To Finger
Posted by naplak on Sunday, August 31, 2003 1:34 PM
True mer1122... Satin is a bit flatter than semi-gloss. But as stated, it ends up depending more on application.
I have had more success getting true flats with lower pressures in my air-brush -- i.e. 8psi
Small pressure chaanges affect the "flatness" of the finish. This can be an advantage when you want you subject to have different finishes in different areas,,, like different panels on a plane.
www.naplak.com/modeling ... a free site for modelers www.scalehobby.com/forum/index.php ... a nice Modeling Forum
Posted by Anonymous on Tuesday, September 2, 2003 10:41 AM
butz you're always there to rib me arent you pal? Wink [;)]
naplak thanks for the tip on air pressure...i'm still working on mastering that as i'm having problems with my regulator...i can see that it's going to do me good in a lot of ways once i manage to get a really low pressure working
