Whats the difference between PVA glue and white glue?
Posted by ipms40049 on Saturday, September 30, 2006 7:46 PM
im trying to fill a stubborn seam, which wont take any other mediums, and people have mentioned using PVA glue? whats the difference between the two?
Pat Hensley Booneville, Ms "Thank you for being here and playing nice"...please do not drag sand outside the box ! CURRENT BUILD(s) Revell 1/72 U Boat VII C Tamiya Willys Jeep - for 2010 Nats Bronco's Staghound -for 2010 Nats Dragons M16 Multi gun carriage - for the 2020 Nats. LOL
    August 2005
Posted by EdGrune on Saturday, September 30, 2006 9:04 PM
google PVA Glue ...
from the This to That website    http://www.thistothat.com/glue/pva.shtml
PVA Glues
Plain old white glue
PVA (Polyvinyl acetates) are probably the most common adhesive on the market. They come in a variety of formulas, all ever so slightly different, and specific to what they are designed to glue. Here are some tips for using Polyvinyl acetates.
  • All PVAs are designed to work on porous materials only
  • PVAs are water based, and clean up with warm soapy water.
  • PVA is only toxic to ingest, it does not emit any harmful fumes, and is not hazardous to touch
  • PVA sets best in good air circulation, at room temperature.
  • PVAs need pressure to adhere, see our info on clamping.
  • Most PVAs are not water proof. The yellow PVAs have a higher moisture resistance than the white ones, but neither are completely water proof.
  • Never allow your PVAs to freeze. This breaks down the polymers and your glue will be rendered useless!
  • Yellow PVAs have a shorter shelf life than white PVAs.
  • Be wary of over priced PVAs that claim to be for a specific use. There is very little difference from one PVA to the other, and nothing that should increase the cost.
  • Although PVA is not a gap filler, in some cases you can add sawdust to it to increase it's gap filling ability.
    August 2005
Posted by eizzle on Saturday, September 30, 2006 10:40 PM
I thought PVA was wood glue and white glue was, well, Elmers? Maybe not, but I also build model rockets, and I use wood glue on them for everything, from paper to plastic, and I have had no problems. I think the white glue or wood glue would be fine as long as you have something in the joint to keep it from running out, like stretched sprue or superglue. The wood glue should also be more flexiable, but you might check out the month before lasts issue of FSM. It had an article about gap filling, and it said for hard to fill gaps, try epoxy putty. Good luck!
Colin
 Homer Simpson for president!!!
    January 2003
Posted by Triarius on Saturday, September 30, 2006 10:47 PM
Technical quibble: Mischief [:-,]
Actually, plain new  white glue. Almost all (there may be a few that are not) "white" or "yellow" water soluble glues these days are PVA. At various points in the past, they were modified acrylic latex, or before that, modified latex. Some PVAs do form a relatively weak, purely adhesive (as opposed to chemical) bond with some plastics. These are the best for gap filling in plastic kits.
