Is it something wrong with my airbrush, or compressor or just me?
Posted by Anthony on Monday, October 2, 2006 10:51 PM
Don't know how to describe it best. But here is how it happens. When I spray my paint (acrylic) from my Passche H airbrush with my Passche compressor (20psi) initially, the paint comes out spray out wild. Instead of a concentrate spray, my paint particals (large size) comes out like shot gun pebbles spray out on a target sheet. Don't know what happen. Sometime when I keep spraying none stop for a while, it comes to normal. Any suggestion to solve this? Thanks.
Posted by gjek on Monday, October 2, 2006 11:07 PM
I don't know the circumstances but is your paint thinned properly? Have you cleaned your airbrush really well? Have you lubed your airbrush after a good cleaning.  Greg
Msgt USMC Ret M48, M60A1, M1A1
    December 2003
Posted by buff on Tuesday, October 3, 2006 7:13 AM
You could try straining your paint.  That might help too.
On the bench: 1/32 Spit IXc
    January 2004
Posted by MusicCity on Tuesday, October 3, 2006 1:03 PM
First, the Paasche H is an external mix airbrush.  That type of airbrush will always have a coarser pattern than an internal mix airbrush.  Next, acrylics dry very, very quickly.  The most likely cause of your problem is that the paint is partially drying in the air between the airbrush and the model.  Twenty psi just makes that worse because you are probably holding the airbrush a lot farther from the surface just to keep that high pressure from splattering the paint.  Try adding some acrylic retarder to your paint mix, reducing the pressure to no more than 15 psi (I prefer 12 psi) and getting no farther than 6" (I prefer 3" or so) from the surface of the model.
Posted by Anthony on Wednesday, October 4, 2006 10:11 PM
Thanks guys. It's really good to get help promptly.Smile [:)]
    March 2006
Posted by Shellback on Thursday, October 5, 2006 3:39 PM
thats the great thing about this forum !  Thumbs Up [tup]Smile [:)]
