Painting small Parts
Posted by Anonymous on Thursday, October 5, 2006 9:03 AM
I've read that Paint as many Parts on the sprue as possiable but when that is done when it comes time to glue them together does the areas that have to be joined have to have the Paint  scraped away?or because of CA Glue can they joined without Scraping?
    September 2003
Posted by stindle on Thursday, October 5, 2006 10:52 AM
 If you do paint on the spru you will have to make sure there is no paint where the glue will go. Even if you use CA glue it will stick but the paint may not :P
So scrape before painting.
Posted by ABARNE on Thursday, October 5, 2006 1:56 PM
 FlyBoy68 wrote:
...or because of CA Glue can they joined without Scraping?
The issue is not the CA to paint bond.  CA glue will stick fine to a painted surface.  The real question is whether the paint under the CA glue is bonded well enough to the surface underneath to hold on the part.  If the joint fails, it will fail bewteen the part and the paint rather than between the CA and the paint.  It's always better to scrape paint down to plastic where the parts join, but in some cases you may be not be able to do that, and depending on the exact nature of the joint, it may be OK.  Use good judgement.
    March 2006
Posted by Yann Solo on Thursday, October 5, 2006 2:00 PM
I've tried that and didn't had good results.  I prefer to paint subassemblies.  For armor, I paint the wheels, track and pioneer tools separately then I paint the complete hull and turret before attaching the wheels, track and tools on it.
For aircraft, wheels wells, landing gears and cockpit is painted seperately in sub assemblies and then masked when ready to paint the whole plane.
No matter where you go ....... there you are.
    March 2006
Posted by Shellback on Thursday, October 5, 2006 3:35 PM
Sign - Ditto [#ditto] I agree with Yann . All of the handling during assembly ( glueing , puttying , test fitting ) will ruin your paint job and make assembly more difficult , IMO. Good luck .
    January 2003
Posted by plasticmod992 on Thursday, October 5, 2006 9:47 PM
Same as Yann above, I paint in subassemblies.  However I do sometimes paint parts on their spure, but very infrequently.  The later is really a matter of personal preference, but like already stated, carefully sand/ or scrap the mating surfaces where the parts are to be joined for the strongest possible bond.  Also worth mentioning, use a minimal amount of CA for the application to avoid excess "seep out" from under the joint.
Greg Williams Owner/ Manager Modern Hobbies LLC Indianapolis, IN. IPMS #44084
    September 2006
Posted by ZzZGuy on Friday, October 6, 2006 10:45 PM
For ships i tend to prime on the spur and touch up if needed. The primer will increase the dry time of the glue (i use model master: liquid cement), but it bonds just as good as if there was no paint. No problems with super glue.
As for priming everything else, I rarely prime on the spur tree. I assemble everything untill it is all ready to be painted, i then prime all sub sections and individual parts.
For small parts i use strips of painters green or blue tape turned upside down and itself taped at the ends to a piece of cardboard, this will keep them from moving. I use a spray can to prime (Here is a link to a post that i made on my favorite primer), i spray outside due to fumes, i also took a cardboard box and cut away the the top and one side to make a wind break.
I never paint on the spur, but this is mostly a lack of forsight as some parts that i would paint by itself have the spur tree attached to a non visable area.
Mongol General: Conan, What is best in life?
Conan: To crush your enemies, see them driven befor you, and hear the lamentations of the woman!
