Manufacturing a needle
Posted by Anonymous on Monday, October 16, 2006 5:14 PM
Has anyone ever tried making a needle out of alternate materials?
I know that things don't adhere well to Titanium.
There is wire available in many thicknesses.
Do you think it might tend to clog less?
I was also thinking of carving one out of Lignum Vitae.
http://surfpick.com/hardness
Yes, it's only wood... but a slice barely thicker than 1mm
can withstand being slammed against steel, for years
http://surfpick.com
Lignum Vitae is also notorious for it's poor adhesion properties.
You have to treat it with acetone, to epoxy it.
The wood needs no finish and will accept none.
It appreciates sanding all the way up to 2500 grit,
where it becomes more like a marble finish, than wood.
    May 2005
Posted by Bgrigg on Monday, October 16, 2006 5:40 PM
I've never done it, but primitive peoples used to make them out of porcupine quills, cactus spines, and bone all the time. I am familiar with lignum vitae and see no reason it wouldn't work. Expensive bloody needle!
I once made a mountain out of a molehill, but the results were less then pleasing...
So long folks!
    October 2005
Posted by gulfstreamV on Tuesday, October 17, 2006 1:05 AM
I once made a mountain out of a molehill, but the results were less then pleasing...Big Smile [:D]
Ya know maybe it's worth a try  ?      Lignum Vitae is also notorious for it's poor adhesion properties.
where it becomes more like a marble finish, than wood. If it works in R&D I'm in for an investor.
Stay XX Thirsty, My Fellow Modelers.
    November 2003
Posted by bobbaily on Tuesday, October 17, 2006 5:08 AM
....or maybe just a teflon coating on an existing needle-save the tooling costs.
Bob
Posted by Anonymous on Tuesday, October 17, 2006 1:53 PM
I'm going to play with the concept when my brush arrives.
I went with an HP-BS
If I can find a springy alloy of Ti in a gauge identical to the needle,
it will be a lot easier than making the LV version.
Maybe a Ti shaft, with an LV tip!
Now that's an exotic needle.
Posted by MikeV on Saturday, October 21, 2006 9:27 PM
Manufacturers have looked into this before and it is not cost effective.
I see no reason why a different metal would make any difference at all.
