Painting Resin Accessories
Posted by Anonymous on Monday, October 23, 2006 1:56 PM
Am including resin upgrades to some models I'm building and I'm having problems getting acrylic paint to stick even though I've cleaned the resin using soap & water, alcohol, Windex, and a couple of other things.  The paint stays on unless disturbed in some way and then just flakes off.  Am I whistling in the wind trying to use acrylics on resin?  If so, what is a better choice?
-me-
meady99@aol.com
Posted by ajlafleche on Monday, October 23, 2006 2:23 PM
Use an enamel primer after washing the part in soap and water. Actually, you should prbably prime the whole model..
    August 2005
Posted by EdGrune on Monday, October 23, 2006 2:38 PM
... and your primer doesn't need to be anything exotic or expensive (i.e. with a model manufacturer's logo on it).   Plasikote Gray primer from the local Wally World is an excellent (and inexpensive) choice.   I regulalrly prime my resin ships overall with American Tradition Red Primer from Lowes (and leave the underhull in primer red)
    December 2004
Posted by Hippy-Ed on Monday, October 23, 2006 3:19 PM
Sign - Ditto [#ditto] That is what I do. Why spend more for something that you can get more of for less cost?Cool [8D]
If you lose your sense of humor, you've lost everything
    August 2005
Posted by eizzle on Saturday, October 28, 2006 10:04 PM
I have always heard to let the resin pieces soak in Wesleys WhiteWall cleaner for a day or so to remove the mold release oil. Does anybody do that, or is it a bit overboard?
Colin
 Homer Simpson for president!!!
    December 2004
Posted by Hippy-Ed on Saturday, October 28, 2006 10:36 PM
Overboard??!? Try overkill.  A good washing with soapy water (I use Dawn dish soap myself) and a good rinsing does the trick.
    August 2005
Posted by EdGrune on Sunday, October 29, 2006 8:32 AM
I typically go the dish detergent route (brush with an old toothbrush, rinse well, allow to air dry),  but I have found the Wesley's Bleche White tire cleaner to be effective on heavy/greasy mold release.  It is not an every-time thing.   Again, a similar process is used.  Spray with the Wesley's, brush, rinse, repeat as necessary.  Allow to air dry to minimize fiber transfer.    A multi-day soak is not necessary.   [How often have you found it necessary to soak your whitewalls for a day or two - Wesley's  is a strong crud cutter.]
Conditions vary.  Be flexible.  Be prepared to respond with the most effective treatment for your individual condition.
    August 2005
Posted by eizzle on Sunday, October 29, 2006 1:44 PM
I don't know about the whitewalls... that was pretty much out of style by the time I started driving Big Smile [:D]
Ok, I won't use the Wesleys. Thanks for the info guys!
Colin
    November 2011
Posted by racingsecrertary on Wednesday, November 23, 2011 8:12 PM
i use westleys whitewall cleaner for a lot of things including cleaning my whitewals(old guy) this stuff cleans paint from plastic models, diecast cars and resin parts, i like this stuff almost as much as future.
