Hey ^_^ First post here.
I have a question about Kryon primer since I'm using it, but I figure any automotive primer or primer like Kryon would be able to answer my question. I bought a can of the stuff last night, and decanted it into a little bottle and airbrushed it on my model. The reason I decided to switch from Model Masters was that the model masters primer wasn't covering up the putty I put on my model. I ould still see it, even after a few coats.
I've sprayed teh Kryon on, and it went on smooth, but there's a bunch of little dried bumps all over it. Like little clumps of dried paint. Is this normal? I plan to, either tomorrow night or the following night depending on how school and work leave me, to sand the pieces with with some 2000 grit (not a typo, I mean 2000, with three zeros) I picked up to get the bumps away. Hope it works, but I'm open to tips and suggestions about using this stuff.
I'm spraying it at about 20-25 PSI from a distance of around six or seven inches from the piece. I do four really quick passes, waiting a bit between each pass, then letting it dry for a couple of hours, then doing a few more quick passes.
Thanks for any help!
