Hi Everyone,
I've been airbrushing acrylics (Model Master Acryl) for several weeks and with the exception of some issues with my dual action airbrush (more specifically the level of my skill) I'm fairly confident with it. Just tonight I sprayed with enamels for the first time and here are some thoughts and questions:
1) BOY AM I GLAD I bought a respirator! I finished up, took it off, and was hit by the fumes of the paint and the lacquer thinner. Had I not been breathing through one I would be coughing enamel by now. My garage still has the smell lingering in it. =)
2) I was spraying a 9:1 gloss black:metallic steel mixture. The gloss black was from the MM Enamel line and the metallic steel is from the classic Testor's square bottle. I had this whole mixture combined with 150% as much airbrush thinner (as recommended on the thinner canister). The mixture didn't seem to combine properly, with the black seemingly floating to the top. Aren't we supposed to be able to mix paints from these two lines?
3) I have a bottle-fed airbrush. For you people who spray enamels, do you go through the trouble of completely cleaning your bottles? Or do you dedicate bottles to specific colors and store the paint in the bottles?
4) As smooth as my stint with enamels was, I still prefer acrylics for their easy of use. The reason I had to spray enamels was because my model called for that specific mixture of metallic paint vs gloss black. I see that MM Acryl has colors like 'steel', and 'aluminum', and web photos indicate that they are metallic. Are they reallly? If not, is there a brand of acrylics that has metallic colors that someone could recommend?
5) I read about 'back flushing' this morning and tried it for the first time tonight. I wished I had heard of it sooner: I always had trouble removing my water or windex bottle because the little leftover fluid would splash all over the place when I jerked the bottle free. Unfortunately I had a bottle of lacquer thinner hooked up and I back flushed too abruptly, shooting thinner out of the bottle's siphon vent hole and onto a freshly-painted part. D'oh!
That's about it, any comments you guys have would be greatly appreciated!
Jeff
