Will this compressor work?
    July 2013
Posted by IL2windhawk on Sunday, November 5, 2006 1:02 PM
Thanks for taking the time to read my question.
I found this air compressor at a yard sale for twenty-five cents.  I
want to know if it can be made to work with an airbrush?  I know
for sure that it has the wrong type of adapter at the outlet, and
that is probably needs a regulator and a moisture trap.  Can
anyone give me some ideas on how I could setup this compressor
for airbrushing, and where I can get the necessary parts?  Thanks.
Note the incorrect air hose fitting.
Specs
Max pressure seems to be 30 psi.
  1/32 Revell Duo Discus
  1/32 Revell ASK-21
  1/48 Ardpol SZD-51 Junior
  1/48 Czech Models Grumman Goose
  1/144 FineMolds Millennium Falcon
Posted by Anonymous on Sunday, November 5, 2006 4:09 PM
yup,it'll work,you just need to get the proper adapters,,,if you go to lowe's and get a 1/4X1/4 male,,,then you can screw the airbrush hose adapter on it
    January 2004
Posted by MusicCity on Sunday, November 5, 2006 4:12 PM
Looks right to me.  The entire barbed fitting should unscrew from the compressor.  From the photo it looks like a standard 1/4 NPT fitting to me.
    July 2013
Posted by IL2windhawk on Monday, November 6, 2006 11:40 AM
Thanks.
so once I get to correct fitting, will any regulator work?
  1/32 Revell ASK-21
    March 2006
Posted by Yann Solo on Monday, November 6, 2006 11:48 AM
Yes it will work.  Any regulator and moisture trap could fit.  It's just a matter of having the proper fittings and adaptors.
 Nice deal.
No matter where you go ....... there you are.
    December 2004
Posted by Hippy-Ed on Tuesday, November 7, 2006 9:21 PM
 Nice deal.
I can't agree more Tongue [:P]  a steal for 2 bits!!Big Smile [:D]
If you lose your sense of humor, you've lost everything
    June 2005
Posted by smokinguns3 on Tuesday, November 7, 2006 10:39 PM
Of course its a Binks. The makers of the automotive spray guns.
Rob I think i can I think i can
Posted by John Estes on Wednesday, November 8, 2006 2:28 PM
Yes.  the fitting/adaptor might be for a Badger hose.  If you cannot afford a regulator at this time , just loosen the hose connection and lower the amount of air going through the hose.  As for moisture, without a trap you might get some on very high humidity days.
    July 2013
Posted by IL2windhawk on Wednesday, November 8, 2006 5:53 PM
Thanks for all the input so far.  I really know nothing about airbrushing,
although I am committed to learning, come hell or high water.  I'm sick
of using rattle cans.
Yeah, it was a darn good deal.  I thought, "Heck, why not" when I saw
it, even though I wasn't even thinking about modelling use at the time.
Air compressors are just plain handy to have.  Like I said above, it puts
out 30 PSI, but I just bought a regulator and although I have not tested
it yet the package says that it creates a 5 PSI pressure drop.  So I could
be getting a max pressure of 25 PSI.  Think that will be enough for airbrushing?
I planning to buy a Badger 155.
Maybe I should consider a gravity feed instead? Any advice?
  1/32 Revell ASK-21
    August 2005
Posted by eizzle on Wednesday, November 8, 2006 6:05 PM
25 psi should be more than enough. I normally spray at 15-18. Its all going to depend on how you spray and what you are doing. Gravity feed does use less pressure, or, uses the same amount of pressure, but uses it more economically, its doesn't require airpressure to suck up the paint from the cup, so you will have more air for spraying. I think you will be ok with what you have, unless your wanting to get a new gravity feed, otherwise, you need a new one and you better get the deluxe version with all the little gadgets in the fancy box! Big Smile [:D]
Colin
 Homer Simpson for president!!!
    August 2005
Posted by Phil_H on Wednesday, November 8, 2006 6:05 PM
25 PSI should be plenty for most model airbrushing.
Just a note of caution.
Being a diaphragm-based type, I believe you need a bleeder valve in the system on the "output" side to prevent excess back pressure from blowing the diaphragm. Preferably this would be between the compressor and the reg so that the reg gives a true reading of the pressure being delivered to the AB. (That is, unless the reg is designed for a diaphragm comp and incorporates a bleeder.)
Posted by Anonymous on Thursday, November 9, 2006 1:30 AM
To get over the backpressure problem buy a foot switch and wire it in this allow you to switch on and off as required, saves any overheating as well
Ted
    July 2013
Posted by IL2windhawk on Thursday, November 9, 2006 10:29 AM
^--- are you suggesting that turning the compressor on for just brief moments
when i need airflow will keep back-pressure from being a problem?
Bleeder valve, huh?
I didn't see those at Lowes yesterday.  Just a couple bucks, I assume?
  1/32 Revell ASK-21
Posted by autocar1953 on Thursday, November 9, 2006 10:38 AM
As to the back pressure problem-- if you drill a 1/64 hole in the 1/4 x 1/4 fitting so that the acts as a pressure relief, this will solve that problem.
I have one of these-- they are noisy because they run all the time and they are hard to regulate pressure.
I used mine to fill a nine gallon tank I got from Sears, and airbrushed with that.
I now use a pancake compressor and regulator/watertrap. (also from Sears, about 200.00/total)
500 started, none finished....
James
