Hi Everyone,
I've not been on these forums for a while...its good to be back!
I have recently been switching to acrylic paints and have discovered a neat trick to thinning Xtracrylix from Hannants that I thought I must share with fellow builders.
I tried various methods all with varying degrees of success.
But the best way I found was using good old tap water, BUT...it must be warm tap water, just like you'd use for decalling. Don't know why...but it seems to work a treat.
FYI I use a Ripmax compressor set a 10-15 psi and an Iwata HP-C Revolution airbrush, the thinning ratio was 50:50
Hope this helsp people here!
regards,
Mike.
